Home Forum Ask A Member Johnson TN-28
Viewing 10 posts - 1 through 10 (of 28 total)
  • #181972
    tinkerman
      Finally got back around to putting my TN 28 back together (new pistons rings crank and gaskets) maybe I waited a little too long. I’m waiting on my coils to show up(Monday I hope) and was going thru and making sure I remembered where and how everything went. Got most of it ok but I’ve got two small springs that I’m stumped on I only see one in the carb diagram and it’s not clear where to connect both ends. Any help would be appreciated. The second one I. Not sure at all where it goes, I was thinking nutreul clutch? I’ve got it back together and it seems to be kinda spring loaded on its own. Anyway thanks for all the help
      It's a jungle out there.
      #181973
      dave-bernard
        Got pics ?
        #181979
        tinkerman
          I’m posting a pic of the 2 springs and also the top portion of carb linkage as it’s hooked up now. Looks like something , a pin at least should go thru the brass tip maybe one of the springs but a spring there doesn’t look like it would control the linkage in any way only serve as a keeper
          3083E4C6-4F53-49EC-98A3-B50B41E30241
          97803D29-B161-417C-A145-080931AAF166
          • This reply was modified 5 years, 7 months ago by Mumbles.
          #181982
          steveh
            Here are two photos showing spring locations. You might need to zoom in on the second one a little and the actual attachment points aren’t all that clear, but I hope it helps.
            2013-03-23_05-37-45_569
            2012-12-16_11-04-31_299
            #182003
            tinkerman
              The second pic with the neutral lever spring I got figured out thanks to the pic. The first pic looks like is of the bottom portion of the linkage and that little spring is on the lower part of my linkage as I never took it off however at the top of the linkage where it attaches via a small bracket to the little brass pin….. I’m not sure if a pin holds the linkage on or a spring. The spring I have left is approximately the same as the one that went on the neutral lever
              #182051
              tinkerman
                One question leads to another I’m waiting on a reply about the second spring but I got the coils in set the points and when I put the flywheel on with NO tension on the flywheel nut “something” is rubbing when I move the spark advance. I’ve moved the shoes of the coil as far as I can get them to go but still rubbing. I’m posting a pic does everything look right to the trained eyes?
                19E791DB-9B65-42DF-A5D7-BDD06796D6FF
                94F70EC1-C7C7-4FC0-BFBB-4B52369BC832
                #182062
                  Looks OK to me. Try putting a piece of masking tape over the exposed ends of the coil laminations, re-install the flywheel and spin it through several revolutions. Then remove the flywheel and look for any rub marks on the masking tape.
                  #182063
                  tinkerman
                    Ok if you stay with it long enough and have patience it’ll come together. I had the wave washer installed incorrectly (on top instead of bottom) and it wasn’t allowing clearance on top of the coils. Still havnt got the final spring figured out and back to the drawing board on the carb it’s leaking fuel EVERYWHERE.
                    #182064
                      OK, never mind my last post. Glad you found the problem. I completely overlooked the rub marks on the top of the coils!
                      • This reply was modified 5 years, 7 months ago by Bob Wight.
                      #182068
                      dave-bernard
                        in pic #2 is that rub marks on the plate?
