Home Forum Ask A Member Johnson TN-28
Viewing 8 posts - 21 through 28 (of 28 total)
  • #182192
    steveh
      The copper washer is the only “spacer”. I think perhaps you do not have the mag plate seated properly. If memory serves, it kind of drops down when it is in the right position.
      2012-10-10_21-10-34_53
      • This reply was modified 5 years, 7 months ago by Mumbles.
      #182203
      lloyd
        Not sure what you mean when you say “timing cam”. Maybe you mean to say the circular magnet? In any case there should be no washer or spacer under the magnet. The wave washer should be on top of the magnet as shown in the photo above. And there should be no “wave washer under the disc”?? Maybe that is what is pushing your magneto plate up too far.
        #182210
        lloyd
          Now I am completely confused. The photo of the magneto in page one shows a later magneto with the coil heels facing out towards the flywheel magnets and the photo above on page two shows an earlier magneto with the coil heels facing in towards the central magnet. Are we talking about a TN28 or some earlier motor??
          #182212
          tinkerman
            I did not post the pic above but I’m gonna post a few here of how I have it assembled , it is indeed a TN 28 and yes Lloyd I was indeed speaking of the circular magnet
            7DBA1ECF-52A5-45EC-BF2B-ABDA78FB89EC
            F4627757-0AF7-4E57-8968-9AA4C7EA5AED
            B828F1B8-1452-488B-A97A-4A16221C3AD7
            It's a jungle out there.
            #182217
            tinkerman
              Also Lloyd if you look back on the first page at the picture that has the red circle and arrow on it…..is this the correct way the carb linkage installs? I believe your the guy that sells the leather washers so I’m assuming that you know more than most about these lil motors. And thanks
              #182259
              lloyd
                Yes I am the guy that makes the leather primer seals. I am not absolutely certain, but I think your carb linkage looks correct. Been a while since I looked at one from the perspective shown in the photo.
                #182260
                tinkerman
                  If it was easy then it wouldn’t be challenging and if it’s not challenging it’s not fun. I think I’ve got the rings seated good. No it didn’t start but I used a manual rope and pulled it about 100 times lol. Spraying fuel mix in the mixture valve. It would kinda sound like it was trying to hit but no smoke or nothing. Then I crossed the plug wires just to see and it coughed and sneezed more but after reading and tracing wires they were right the first time. I’m in the process of ordering the coil spacer ring as this is the second motor I’ve needed it. I put the wave washer and armature back on first and still couldn’t find a mounting problem. Tho it probably wasn’t the “right” thing to do, I took a grinder and hit the underside of flywheel where it was rubbing the armature and it’s not hitting anymore. I’ll get it eventually, it’s just a hobby.
                  #182268
                  crosbyman
                    did you follow this procedure…
                    http://pochefamily.org/outboard/CarbService.html
