Home › Forum › Ask A Member › Johnson VR-45 racing outboard – rotary valve
  • #184336
    David McFarlane
      I am restoring my father’s Johnson VR- 45 racing outboard which was manufactured in 1929. To enable the restoration the rotary value which
      was damaged in a accident has to be replaced.I am seeking a member who could possibly help me with information, or a possible contact to secure this part.
      I live on a farm near Ballarat Victoria Australia.
      David McFarlane
      #184339
        Randy Reiniger in Tampa is the only one I know with parts for those Rotary Valve Johnsons . . .
        #184362
        Randy in Tampa
          I think I contacted you on Facebook, do you need the whole rotary valve or parts?
          Rotary valve Johnson’s Rule!
          #184420
          lloyd
            I hope he has a copy of the “Outboard Racer’s Handbook” so he can set up the proper rotary valve timing for desired low and high speed performance. The only spare rotary valve I have is for my already complete, restored and running PR. Don’t remember if that spare rotary valve or any of it’s parts are compatible with the VR rotary valve.
            #184428
            David McFarlane
              I need to replace the whole valve. We tried to re-cast a mold without success. See attached photos.
              I’m not on Facebook.
              #184433
              David McFarlane
                It would be greatly appreciated if I could get a copy of the timing book. Do you know where I could find one on the internet? Thankyou.
                #184446
                lloyd
                  The top plate and gear on my spare valve look the same as yours but your body and induction ports look larger. I can’t find my copy of the Outboard Racer’s Handbook right now. We moved 2 years ago and some of my files are disorganized. I don’t even remember where I got my copy about 10 years ago. Hopefully someone on this site will know where to get one. Lots of valuable information about compression ratios, appropriate fuels, rotary valve induction timing, etc.
                  #184448
                  Randy in Tampa
                    I don’t get your rotary valve has it been modified? the V 45 had a Johnson carburetor on it, that fit on it with a clamp that one appears to have an adapter welded onto it to fit the Vacturi AO 500 carburetor …🤔
                    #184449
                    Randy in Tampa
                      Also what is the diameter of the top gear?
                      #184458
                      David McFarlane
                        Re the Instruction book, I found my copy on the internet, and will look for the Outboard Racer’s Handbook. If you find yours, would it be possible to send a copy? I will pay postage and any other cost, of course.
