Home Forum Ask A Member Just got my first big outboard!
  • This topic has 12 replies, 12 voices, and was last updated 7 years ago by 76-j.
  • #84942
    dockbuster1
      The drive shaft splines tended to fret use a good spline lubricant and check the seal surface on the drive shaft the steel rusted and cut if so a speedy sleeve does a good job before replacing the seals in the w/p base
      #84949
        I remember a few of those 650s from about the 1970 era that idled very well…. even without a thermostat. Like all pre-1976ish Mercs, water in the gear case is almost a given. Ideally you will want to rebuild and reseal but at the very least, refill it with oil and spin it over with the starter to preserve what may be left.
        #84951
        76-j
          Many 650 / Panther Merc’s (OEM) have the Thunderbolt Ignition, notorious for breaking the timing belt…a "fix" is to substitute a Kiekhaefer 4-D magneto, as it has less drag.
