Home Forum Ask A Member just saw this today
  • #204819
    albator
      hello i just saw this today i dont know the year and i can have it for peanut it was in good running condition 10 year ago .are they good motor?
      7.52
      7.53
      7.51
      • This topic was modified 4 years, 6 months ago by Mumbles.
      #204828
      bobw
        That’s a 1955 model 7.5hp. Good motors and if the price is right, grab the motor and the tank!
        #204831
        crosbyman
          Canada Member - 2 Years
          grab it fast…pay the man his peanuts…
          https://www.bing.com/videos/search?q=utube+1955+7.5+outboard&&view=detail&mid=20B142FA2836945990BA20B142FA2836945990BA&&FORM=VDRVRV
          • This reply was modified 4 years, 6 months ago by crosbyman.
          #204833
          aquasonic
            Wow! Don’t let that one get away!
            #204846
              I’d give the whole plantation for it!
              Does it have the correct pressure tank to go with it? 16:1 fuel mix.
              #204872
              need2fish
                It’s beautiful ! Maybe not so much on the insides — as good as the exterior looks, the motor may have been stored for long time without maintenance.
                Consider going through:
                o Carb and tank — clean them — over time the fuel can harden and block fuel passages
                o Magneto. If the coils have never been changed, it’s likely they’ll need replacing as the OEM units of the era cracked alot
                o Lower unit. The seals may have hardened so much that they’ll pass water. drain, flush, fill and test. Repeat.
                o Cylinders. Pop off one of the bypass covers to and take a peek at the rings and pistons to ensure the bores aren’t filled with rust.
                Although my 7.5 spends all of its time on a rack, it’s super reliable and the perfect size for pushing a 12 foot aluminum or fiberglass boat.
                #204884
                outbdnut2
                  Those are sweet-running motors, and quiet compared to other motors of the 1950s. The tank can be worth as much as the motor sometimes. I have three of those 7-1/2s.
                  crosbyman
                    need2fish….i would jump on it without a blink if the price was peanuts….….whomever had this motor surely took care of it by looks alone. A lot of uglies run fine so a beauty like that has all the chances of being a great runner….
                    #204917
                    fleetwin
                      US Member - 2 Years
                      Yes, that appears to be in original pristine cosmetic condition, a rare find… Please don’t buy it with expecting to put it on the boat and take off. The engine will need ignition/fuel system/water pump/gearcase servicing in order to be a reliable daily runner. Check the inside of the fuel tank. Just because it looks nice on the outside doesn’t mean it will be clean inside.
                      This beautiful engine is almost too nice to be used constantly, should be saved for special occasions, but that is up to you…..
                      Stick with the original fuel mixing instructions: 16:1, ignore all the hype about today’s oils being superior so less is needed…This engine has plain connecting rod bearings, and needs plenty of oil or it will be ruined quickly….
