Home Forum Ask A Member KE-4 Carburator HELP
  • #161373
    goldmember
      I have a KE-4 with a Tillotson AJ23A carb and I took it apart a year ago and lost my pictures. I have a couple questions.
      1. Which way does the throttle butterfly plate go? Open part up, down, which side, does it matter?
      2. Is it supposed to go in the slot of the throttle shaft?
      3. Do I have the top linkage right?
      4. How does the spring go on?
      Thank You
      #161379
        Here’s a couple of pics, Top one of a Mark 5 carb. Not sure what Merc
        the other is from, or if they are
        similar enough to yours, or show what you need to know.
        DSCN5037
        Mark-5-carb
        • This reply was modified 6 years, 3 months ago by Buccaneer.
        #161384
        dave-bernard
          open down.
          in the slot
          looks correct.
          spring call me after 4:00 pm today.
          Dave.
          #161392
          goldmember
            Thank you
            #161395
            Randy in Tampa
              I have a KE4 and not being a mercury guy I had the same problem A while back, I about beat my brain to death figuring it out 😉
              Rotary valve Johnson’s Rule!
