Home › Forum › Ask A Member › KG-7 with green Q value
- This topic has 5 replies, 3 voices, and was last updated 3 years, 1 month ago by
Chad Ruedin.
March 1, 2022 at 3:59 am #255457
Hi Chad,
I do not consider myself an expert – far from it – but if you came across this motor and hydro on Craigslist in the last few days (https://rochester.craigslist.org/boa/d/marion-vintage-hydro-boat/7450686489.html) I am thinking you may have found a KG-7Q powerhead mounted on a ‘service’ or ‘fishing’ KG-7 mid-section and lower unit. That is still a rig many would be proud to own, but it is not an original, complete KG-7Q racing motor – one of approximately 500 that left the factory with a green silk screened ‘Q’ on the serial number tag. The Q mid-sections and lower units (there is a picture on Wikipedia (https://en.wikipedia.org/wiki/Mercury_KG-7Q_Super_10_Hurricane) are very different to the ‘service’ or fishing’ versions. There is a possibility, too, that you have an original KG-7Q serial number tag on a replacement powerhead (if the number on the powerhead doesn’t match the tag), further reducing the potential market value. None of this should sway you however if you like the rig and you are comfortable with the price being asked. The above is offered with nothing more in mind than having you understand what has been presented to you! I will let others comment on the estimated value of this motor – opinions do vary! I hope this is helpful.
eggbeater
March 1, 2022 at 2:40 pm #255472Yep that’s the ad! I was hoping I found something worth a lot more no one knew about. I appreciate the reply! That helps my decision.
March 1, 2022 at 9:13 pm #255497Chad,
Some history on the KG7Q
In 1950 Mercury engineers came out with the Super 10 Hurricane, Model KG-7. This motor was based on previous models KE-7 Lightning and KF-7 Super 10. Upgrades included redesigned connecting rods, upgraded aluminum clamp and swivel brackets, a new high RPM magneto, improved porting, an 8 Reed valve cage (as opposed to KE-7 and KF-7’s 4) and larger crankcase opening. Hurricane was also advertised at 10 hp*, way below the actual horsepower developed, Mercury noted this asterisk by stating that horsepower varies with rpm; really the Hurricane could deliver up to 18 hp. Shortly after the introduction of the Hurricane, Mercury came up with their first performance gear case with the capability of mating to a standard driveshaft housing of a KG-7 or similar green top engine of the time. This was named “Quicksilver” and promised an extra 20 to 30% increase in top speed. Essentially, it boasted a significantly slimmer pointed gear case that housed an integrated rubber rotex water pump and forward only 1:1 gears along with the necessary bearings. After a few months of use, Mercury found that the average race boat’s transom would not elevate the standard driveshaft housing and quicksilver gear case high enough for peak performance. Rectifying this problem, Mercury developed the Quicksilver driveshaft housing. This new driveshaft housing was three inches shorter which in turn lowered the motor’s center of gravity on the boat which helped turning ability, reduced the strain on the boat’s transom and motor’s clamp brackets, and decreased underwater drag while increasing top speed as less gearcase was below the boat. In addition the motor had a sort-of cut down lower anti-cavitation plate, protruding forward upper anti-cavitation plate (spray plate), a stronger rear-mounted steering bar design, and finally, an exhaust opening above the water surface that reduced exhaust back pressure while increasing noise levels when the boat was on plane. When the dealer installed the quicksilver driveshaft housing and gear case (packaged at $82.25) he had authorization to hand stamp a small “Q” behind the serial numbers on the tag and block. Some did, some did not – and so, the “Stamped Q” came to be. 1951 saw the first production race-ready outboard models; KG-4Q, KG7-Q, and KG-9Q. These motors were pulled off the production line at random, given the quicksilver gear case, driveshaft housing, and “Q” stamp behind the tag serial number and block serial number. These KG-7Qs worked fine on runabouts but were too long for hydroplanes – and the racers made this known to Mercury. So thus was born the 2″ shorter “H” driveshaft housing in 1952. Right before Mercury released this “H” driveshaft housing, they still had several “Q” length driveshaft housings, so they introduced a factory KG-7Q which had a green silk screened Q behind the serial number on the tag and a factory stamped “Q” on the block. These motors are very rare; they fall into the serial range of 532404-532963.
Travis
AOMCI VP Communications
AOMCI Webmaster
webmaster@aomci.orgMarch 3, 2022 at 7:46 pm #255576Chad,
So the link to motor & boat provided by eggbeater is rough only by looks would need to go thru it to let you know mechanical condition. Yes it is showing the Q which would come with the Quicksilver Lower Unit, pictures in that add show a service lower unit so somewhere down the line is the original Q Lower unit? Was it removed /looks like gone due to i don’t see it in the ad, might want to ask the seller where it is… Value to the motor drastically decreased without Quicksilver lower unit… Hope this helps…Travis
AOMCI Webmaster
webmaster@aomci.orgMarch 4, 2022 at 2:31 pm #255595Yes helped a ton with all replies!!
