Home Forum Ask A Member Lauson motor
  • #277500
    Gary Peterson
      Hello..
      We have rec’d a Lauson motor that has been sitting for a long time. Could this be a serial number? 70B1955. Photo attached.
      #277511
      jcrigan
        That is the only identifying number that you will find on that motor. That is a Lauson model 410. the last four digits would be the serial number. the 7 may indicate that is a 1947 motor. I am guessing on the year. It is a 2.5hp,, 4 stroke, single. It takes around 10 ounces of 30 weight non-detergent oil in the sump. Polish the points and set at 0.020″ in. Check for grease in the gearbox. It should run and idle slow when running right.
        #277523
        Gary Peterson
          Thank you so much! I found some pictures of a couple of motors that look like one we have and we thought it was a 1947. We will follow your instructions. Thanks again,
          #277526
            Not Mine.
            #277552
            Gary Peterson
              Ours looks exactly the same! I have been cleaning it, for now enough so we can handle it and I found another number. OB 4483. Could that be a serial number? It is on the mounting bracket for the drive shaft, exhaust
              #277767
              Gary Peterson
                Hello…I am wondering if a parts manual, or owners manual exists for this motor.It is a Lauson 410 and looks just like the image above.
                #277773
                  Check this link for some more info.
                  https://www.aomci.org/forums/topic/lauson-outboard-info/
