Home Forum Ask A Member Leaky gasket on older Tempo plastic tank
  • #260849
    lindy46
      I’ve got an older Tempo 3 gallon plastic gas tank that was leaking gas around the gasket where the fuel gauge is mounted. So I got a new gasket.  When I took the old gasket off, there was no gasket cement or sealant – just the rubber gasket. So I didn’t use any sealant on the new gasket. She’s still leaking when she sits in the hot boat. Should I have used a sealant?
      #260877
        No sealant. See if the pick up assembly is warped. Those were the worst tanks ever made. If gas didn’t leak out, then rain water leaked in. It always amazes me that Tempo never got sued for those things. Best use is to cut them in half with a hand saw. They make very robust drain pans.
        #260924
        lindy46
          Looks like it wasn’t the gasket but the threads where the brass fuel line connector screws into the tank. I found out when I had it apart and blew into the pick-up tube. I removed the connector and put some pipe thread dope on and it now seems okay. I’ll let it sit in the sun awhile and see what happens.
          #260994
          amuller
            I agree. These tanks suck.   Entry of water is common.
            #261048
            78bluestreak
              My fittings are not brass, but aluminum.  Careful with the plastic threads.  Agree to use Teflon pipe tape.
              #261057
              lindy46
                I had Teflon tape around the threads and that’s where it was leaking. The pipe thread stick seems to have done the trick.
