Home Forum Ask A Member Leftover Screws: 1957 Evinrude 5½
  • #1513
    oldoutboardjim
      Okay, I replaced the water pump impeller in this motor, which requires removing the powerhead. When I had it all together, I have two screws that don’t have a home (the top two screws in the photo, below; i.e.: the short ones – I know where the other stuff goes). I’m racking my pea brain trying to figure out where they go. Help!
      #16168
      ray-schaber
        They may be from the vertical shaft that goes from the tiller to mag plate. Holds the guide strips.
        Ray
        #16170
        oldoutboardjim
          quote Ray Schaber:
          Ray
          Thanks for the suggestion, but sorry, these are not for the throttle linkage "Control Lever" "Brg Clamps". I kept those two screws partially screwed into their original locations, and that assembly is complete. These two short screws are for something else.
          #16171
          mr-asa
            Install new points/condensers with new screws?
            Hold-down screws for the strips that hold the plug wires?
            #16172
            Doug Wilson
              US Member - 2 Years
              could those go on the top of the air horns on the carb?
              Doug
              turned off?
              #16175
              david-bartlett
                The screws that hold the high and low speed stops?
                #16183
                marvk
                  I’m with Doug. If they are not from the throttle’s vertical support bracket, I bet they are from the carb silencer. I just had mine apart last night.
                  #16192
                  archangel
                    Add me to the "top of the carb silencer" list. Short screws with the lock washers sure look like the vertical screws for the air intake silencer.
                    #16193
                    aquasonic
                      I think that Mr Asa is on the right track.
                      Those are Pan Head screws with ’rounded’ sides and star lockwashers which are common on the armature plate. The only other place that I can think of them is on the starter housing mounts, but those are larger, and there are three of them.
                      The control arm bracket screws and the air intake/silencer screws are usually Fillister Head screws with the ‘square’ sides.
                      #16196
                        Sure do look like condenser screws. Or from the clamps & stuff on the bottom of the mag plate. But you didn’t indicate you were into the magneto. Or were you?
