Home Forum Ask A Member lightwins 3hp
  • #216652
    backwater52
      I have 4 lightwins, the one i just picked up (66 or 67 ducktwin folding) has no spark on lower cylinder. My part motor (63 lightwin) has great spark, how hard would it be to change whole stator plate? thanks
      #216655
        Real easy. First remove the lower shroud and the starter/gas tank, the flywheel, then undo the four screws holding the mag plate on and lift it off. That’s it. Oh yeah, you will have to undo the spark plug connections to.
        #216656
        backwater52
          Thanks Mumbles! I have a repair manual somewhere so should be good to go. Only thing else i could use is suggestion on where to to by or brand to get for carb kits parts, there is some junky stuff I’ve found the hard way.
          #216658
            I’d stick with an original OMC/BRP carb kit available thru your local BRP or Evinrude dealer. 439071 should be a good P/N and the kits are also available from multiple sources found online.
            #216660
              OEM carb kit part number 439071, Includes a new float. Any Evinrude dealer or marineengine.com
              #216690
              crosbyman
                Canada Member - 2 Years
                what is wrong with the mag plate if you are just missing some sparks ??
                if the float is ok a good carb clean should do …
                #216729
                backwater52
                  Not sure what condition the ignition is in other than no spark on bottom cyl, once i get that firing will get better idea on carb. Adding a inline filter, plus the tank is spotless inside. checked it with a scope my friend has, rinsed it out looks great. Motor was ran last fall by a duck hunter who owned it for awhile. Waiting on carb kits and impellers, should have 3 out of 4 running soon. Got a pile of chores to get done but cant wait to get motors going.
                  #216733
                  crosbyman
                    #217029
                    backwater52
                      Well i had some time but worked on the 65 lightwin i had on my work stand. Earlier i did a carb rebuild and it wouldn’t stay running. Wasn’t flooding just seemed to run out of fuel. Took the bowl off and nozzle, needle and float. Sprayed carb cleaner in every hole available and tweaked float angle. Not sure what i did but it’s running smoooth! Started right up And pushed choke off and put it down to idle and just purred. The fixed jet at the bottom “may” have been blocked, not sure but just happy it’s running! Need to replace impeller, no water at all out of the 2 rows of holes so shut it down fast. Ducktwin next.
                      #217110
                      crosbyman
                        Great… another one for the kids…to come
                        I sold 3 of them to a friend’ s buddies & kids for their fishing needs…. all happy campers
                        great little motors
