Home Forum Ask A Member Loc-tite on rod cap bolts?
  • #1337
    beerman57
      For a QD19, no lock washers or other means of keeping bolts from backing out.
      #14827
        Use an accurate torque wrench, and that’s all it needs.
        #14829
          US Member - 2 Years
          Mercury asks to not reuse their locking type nuts on every teardown. Use new ones from the factory.
          #14844
            When torqueing the rod bolts, along with all the other powerhead components, I use my inch/lbs wrench, and torque in 3 passes, starting with 1/2 the torque value, then 3/4, then the final.
            As Frank stated, nothing needed on bolts other than the proper torque.
            #14852
              US Member - 2 Years
              Chris,
              You bring up a good point to tighten in percentages using the pattern suggested by the manufacturer. Been doing that from my 55 Chevy stove bolt 6 head gasket problems. Helps mucho!!
