Home Forum Ask A Member Lockwood 72T Coil Removal
Viewing 10 posts - 51 through 60 (of 74 total)
  • #285036
      Tim, it looks like you’re off to a good start.
      I can’t imagine why that coil would need any support,
      being it’s suspended on a sturdy laminate, and it
      appears that it’s not going to slide around either.
      The Boat House
        T….in Wisconsin
          Tubbs, I appreciate you posting these instructions.
          Today I’ll put the the flywheel on and verify spark at each plug.
          Multimeter showed good continuity across primary & secondary.
          T… in Wisconsin
          #285066
          The Boat House
            Be careful not to have the magneto too far
            advanced  as this thing can hurt you.
            joecb
              Not to worry too much about the capacitors… the real high quality ones are +/- 10 % on rating, I would guess that the run-of – mill caps that are used on our motors are more like +/- 20%
              #285074
              T….in Wisconsin
                Testing:
                I’m not detecting any spark at either plug. Held the spark plug connector during flywheel rotation and didn’t feel even the slightest trickle.
                1. Primary & secondary verified with multimeter
                2. Filed points
                3. Tested with both new and old condensers
                4. Tested with spark tester and new plug
                5. Scratched head
                T…in Wisconsin
                #285076
                  I guess I’d check the simple things first.
                  Are the points accidently grounded?
                  Condenser bad?
                  Are both sparkplugs grounded when checking spark?
                  Points opening okay and gapped correctly?
                  #285077
                  The Boat House
                    I have experienced this when doing these
                    coil substations as have others.
                    With the spark plugs out and both plug wires
                    grounded to the motor, Spin the motor over with
                    a drill or pull the motor over as fast as you can
                    about a dozen times with both plugs grounded and
                    watch for the spark. I don’t under stand it and
                    cant guarantee this will help but it has worked for
                    me. Here are some of replies from others who gave
                    it a try.
                    Tubs.
                    #285084
                    The Boat House
                      In the above post it should say – with both
                      spark plugs grounded to the motor – not plug wires
                      grounded to the motor – however that still may work.
                      stanley
                        US Member - 2 Years
                        In addition to the things Buccaneer listed I would disconnect the kill switch and add insulating tape to protect against arcing from soldered coil connections to flywheel.For comparison here is a pic of my mag plate.This set up has been run successfully many times and produces a spark that will jump more than 1/4”when pulled by hand.
