Home Forum Ask A Member Lockwood 72T Muffler shell bolts
  • #285406
    T….in Wisconsin
      Need help with dimensions for these 2 bolts. They are slightly different in length from side to side. I plan on having these bolts made locally. Hole OD on my muffler shells is 5/8″, although some were 1/2″ depending on mfg. date.
      Attached picture is that an AOMCI member who has made his own.
      Those listed on ebay are of the same length. I may end up buying them just to have something to work from.
      Any help greatly appreciated.
      #285496
        US Member - 2 Years
        Tim,
        I know nothing about your bolts, but, a guy can buy tools for measuring threads & bolt diameters, even thread chasers for repairing threads will function. I used thread chaser tools on many Mrcury internal gearcase threads to repair tthem, a common tool.
        #285497
        joecb
          The  e-bay bolts look to be nothing more than standard hex head hardware bolts with a tubular bushing slipped over…. might be a functional replacement but far from original looking.
          Unless memory fails me ( not unusual) there was an article in the “Antique Outboarder” years ago about these bolts, with dimensioned drawings.
          #285502
          T….in Wisconsin
            Thank Joe.
            Being I have the Muffler Shells, it may be easier to reverse engineer the bolt for dimensions.
            Thread length would be thickness of mounting flange and a few extra threads.
            Mine has 5/8 dia muffler shell holes.
            I like the member design, just need to figure out a few dimension to it, not a biggy. Lol, I’ve said that before!
            #285514
            David Bartlett
              Tim,
              this is from the July 2010 issue of the Antique Outboarder.
              It may or may not be helpful.
              David Bartlett
              #285519
                US Member - 2 Years
                Tim,
                I see from the drawings these bolts are 1/4″ X 28 threads per inch.  That thread is just a common 1/4″ fine thread, very easy to find.
                #285526
                joecb
                  Thanks  for posting, David… my memory didn’t fail completely this time
                  #285530
                  T….in Wisconsin
                    Good find, I’ll check out the article.
                    I see it was noted the mounting flanges were prone to stripping and breakage.
                    Using a threaded stud and altered bolt design shown in the article is a good idea.
                    Thanks for finding!
                    #285589
                    T….in Wisconsin
                      Dave, did you find this article on this site somewhere.
                      I’d like to read the entire article and I Don’t see where it’s available in the Antique Outboarder Archives.
                      T…in Wisconsin ” My first idea is rarely the one used”
                      #285596
                      David Bartlett
                        I have the issue. I can copy it and send it to you. PM me your address or email as it’s only 2 pages. I could probably just send you a scan.
                        David Bartlett
