Home › Forum › Ask A Member › Looking for a owners manual for a QD 15 10 hp Johnson outboard
- This topic has 14 replies, 5 voices, and was last updated 5 years, 7 months ago by
Rider.
August 29, 2019 at 11:12 am #182263
Thank you Mumbles thats what i was looking for
the hood i got has the wing bolts but has white paint on the sides instead of the dull aluminium paint i wonder if the end of 54 they changed to the white
Definitely ’55 style paint with the Cream trim so it could possibly be an early ’55 if it has the ’54 wingnuts. I’ve seen that before on the 5 1/2 horse motors so they were probably using leftover parts from the ’54 models.On the other hand, it could be a real late ’54 using the ’55 paint scheme. What’s the serial number on it?
August 29, 2019 at 2:44 pm #182269The serial number is 1111839
i want to paint it with the correct colors thank you for your help
August 31, 2019 at 9:45 am #182336not much difference between the qd15 10hp and FD version of the 15hp this may help
see url on top
Great Crosbyman! You found a way to display that URL to people!
September 6, 2019 at 10:24 am #182754Thank you Mumbles thats what i was looking for
The ’54 still has the Seahorse logo cast into the earlier style exhaust leg and no rubber isolation mounts. If it is an “early ’55” situation like many of us have encountered with the CD models, I’d say it would have the thumbscrew retainers on the cover but have the later ’55 exhaust housing and rubber mounts. Those are the things that really defined the ’55 motors.
-BenOldJohnnyRude on YouTube
September 6, 2019 at 4:50 pm #182791thanks Ben i just checked the qd 15 and it doesn’t have the rubber mounts like my qd16 so i am guessing it would be the dull aluminum trim
the cover i have is pretty rough pitted and the hing pin is seized and broken in the front and back halves so i will repair that when time allows-
This reply was modified 5 years, 7 months ago by
Rider.
