Home › Forum › Ask A Member › Looking for help finding skews (lower unit ) for Evinrude 1940 to 1947
- This topic has 9 replies, 4 voices, and was last updated 8 months ago by
oldlure.
July 9, 2024 at 9:43 pm #289007
I am working on a 1946-1947 Evirnrude Ranger 1.1 ho 4407. It is in great shape except the skeg is broken and I am trying to find a replacement for it. If you know of a parts motor that I could get a good keg (lower unit from) please let me know. I understand that the Elto 1940 1941 Pal is also the proper fit. Thanks for any help here. Paul Hastings
July 9, 2024 at 11:26 pm #289010how bad is it ? trashed ? .. partly broken. ?…they can be welded
I have even used JB weld (10$) instead of a 300$ weld job for a small section of skeg on 75 hp ETEC .
the asking price was so ridiculous I got creative.
sanded and spray paint finished with Etec Blue ……. certainly good enough for me
July 10, 2024 at 10:34 am #289016My apologies. My title should have read skeg not skews. (auto correction got me). I believe the part number for this gear housing which is part of the skeg is 195 587. Thanks so much. I have thought about taking it to an aluminum welder but I imagine it would be very very expensive
July 10, 2024 at 11:15 am #289018if the housing is not cracked you can fix it with JB weld.
just dont rest the engine on the tip you fixed or hit…rocks ! paint it silver
nobody will know but you
I used a flat blade . I clamped a drywall spatula (6 inch) wipe with oil and worked the top side to shape the skeg.
just clean the ragged edge with carb cleaner to help adhesion of the jb
July 10, 2024 at 11:29 am #289023Thanks so much for the repair help with JB weld. The problem I have with this method is that I do not have the broken off part of the skeg. I was thinking about trying to cut off the skeg at the base and cut out a whole new piece and shape it and then having it welded on. ??????
July 10, 2024 at 11:38 am #289024If you live in an urban area, there probably are several weldeing shops that work with aluminum. One or more may be willing to repair the ske on a one off cash money basis. It can be done, You may expect to finish job with file and sand paper to get finish and profile.
Finding a replacement part for an 80 year old outboard that may not have been common and for a part that may have been a frequently damaged component may take some doing,
JB Weld probably is not suitable for repair of a broken off and missing portion of skeg.
July 10, 2024 at 11:38 am #289025I did not have the broken section on my 75hp….I just reshaped the JB weld… used a grinder to shape it.
then used a sander to smooth out and match the surface. much like finishing plaster on a wall with 100 grit paper.
welding of course is the best but for just 10-20$ of JB weld it worked for me so…. if you are handy with such work try it
up to you
wasn’t perfect for purist but it came out fine and rock sold
July 10, 2024 at 2:59 pm #289030If I can not find a parts motor then I will either JB weld or I would at least like to get a quote to have one welded at a shop. What I would love to have is a paper tracing of this piece. I believe it is 195.587 in the parts manual. If someone could trace this piece I would be really grateful. Thanks for you help
July 10, 2024 at 5:08 pm #289033just use that picture you posted and adjust it to size on powerpoint
takesa few tries but you can get a good match
July 10, 2024 at 5:28 pm #289034Also check your local prop shop. They weld aluminum props all the time and may do skegs.
