Home › Forum › Ask A Member › looking for information on timing &synchronization for 1980 E15RCSD
- This topic has 3 replies, 2 voices, and was last updated 1 year, 9 months ago by
fleetwin.
July 3, 2023 at 8:41 pm #277667
I really need to find information on carb and timing synchronization for a 1980 15hp evenrude 2 cylinder. any help would be appreciated. thanks Marcus Westbrook, Puget Sound chapter member
Westbrook
July 4, 2023 at 10:38 am #277682There really isn’t much involved with the syncronization of this 1980 15hp. Before we begin, can you tell me why you are concerned with this adjustment? Are you having a running issue?
There are not actual “timing” adjustments on this engine, WOT is controlled by the stop on mag plate linkage. There are not idle or pick up timing settings/adjustments.
So first, back off the little black knob on the port side of the engine so the mark on the black throttle cam is to your left (as you look at the engine from the top/front) to be sure the cam is not touching the throttle roller.
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1980&hp=15&model=E15ECSD&manufacturer=Evinrude§ion=CARBURETOR+%26amp%3B+MANIFOLD
You can back off the screw (#20) if the cam is still touching the roller. It is very important that you ensure that the carb butterfly is actually closed at this point, just because the cam isn’t touching the roller does not mean the carb butterfly is closing completely, there could be some sort of mechanical issue (bent throttle plate or jammed throttle shaft) preventing the butterfly from closing completely. Unfortunately, there is no way of really knowing unless you remove the carb and actually look at the throttle plate. For the the sake of simplicity, let’s assume that the throttle plate is closing completely and there are no mechanical issues.
The objective is to have the carburetor butterfly just start to open when the mark on the cam lines up with the middle of the throttle roller linkage. The engine will run rich off idle if the cam picks up the throttle too late. The engine won’t idle correctly, or stumble/hesitate while accelerating off idle, if the cam picks up the roller linkage too early or the carb butterfly does not close completely.
The tricky part of this adjustment is realizing that there is slop in the roller throttle linkage, so just because the throttle roller starts to move at the proper time does not mean the butterfly is actually starting to open. Using a little alligator clamp on the throttle shaft helps show when the throttle shaft actually starts to move/open. So, with the throttle cam mark in the middle of the throttle roller, turn #20 inward gently until the throttle shaft just starts to move/open. Sure, it is pretty tough to get this adjustment spot on, but it is not that critical to ensure it is “perfect”. It is better to have the throttle open just a bit too late than too early…Having the engine run a little rich off idle is much better than having it run lean and stumble while accelerating off idle, or refusing to idle because the throttle plate is cracked open slightly at dead idle.
Once you start the engine and let it warm up, you may want to adjust the low speed needle slightly and reset the idle speed using the black know on the left side of the engine pan.
Again, I will ask why it is you are concerned with this adjustment…Are you having a running issue with this engine?July 7, 2023 at 7:28 pm #277826Thanks for the info. I checked timing and it looks good. Finally got it started, runs great in neutral but when I put it in forward gear as I advance throttle it bogs down when I get past about 1/2-3/4 throttle and wants to stall out. I took carb apart and it looked clean as a whistle inside. What could be the problem here. compression 99 & 101 cold, new fuel filter screen. Also I think my primer bulb is not functioning properly all the time.
Westbrook
July 8, 2023 at 11:23 am #277862OK, well it sounds like your high speed jet is partially plugged, or perhaps needs cleaning. Did you remove the high speed jet from the nozzle to inspect it? The slightest debris or perhaps a little dirt can affect it. Try pulling the choke out slightly while the engine is bogging down, you probably have a carb issue if the engine seems to pick up with the choke partially closed.
But, like you say, perhaps you have a fuel supply issue. Why do you suspect a primer bulb issue? Do you have the tank vent open? Perhaps try again with the fuel tank cap loose. Pump the primer bulb while the engine is “bogging down”, if it picks up then you have a fuel supply issue.
All that being said, you could have an ignition issue, but I’m guessing it is a fuel issue based on your reports. Feel free to post a video of the engine running/bogging down if that will help.
