Home Forum Ask A Member Looking for wico x8795 coil or possible replacement
Viewing 10 posts - 1 through 10 (of 29 total)
  • #259506
    hondaatc
      Hey fellas i need to replace a wico x8795 didn’t know if any one  had one or knew of a replacement thanks in advance thanks
      James
      #259520
      green-thumbs
        US Member - 2 Years
        Coil looks like it has seen better days, so take it off the laminate by cutting thru one side with hack saw, place assembly in vise and driving the laminate out of coil.
        Next step measure the laminate pole the coil was on and look for a cheap coil that will fit with or without trial and error fitting, It may seem a bit CRUDE, but, adapting a currently available coil beats looking for something that may ve HARD to find. IF you are VERY lucky you may find a used coil at a small engine shop (used) for a nominal sum. Be aware that small engines went to solid state systems about same time as outboards. Coil needs to fit into the available space , fit on the laminate and a high voltage output that can be routed thru the magneto plate without interference with anything  such as flywheel. cam or points.
        I am probably the least qualigied to advise on magnetos. There are those wo REALLY know the subject on this site They may have specific suggestions to address situation.
        Louis
        #259521
          If that is the 2 cylinder coil options are limited.
          If that is the single cylinder coil I used a spare
          (as in free) common OMC style coil in this Wico
          magneto.
          https://youtu.be/tVvSB5QxMrw
          #259524
          hondaatc
            Hi yes its a twin from my beloved lauson 6hp now i have two non runners so its time to do some experiments
            #259526
              A John Deere pony motor coil might work but you may have to modify the pole laminates for the JD coil to fit correctly.
              • This reply was modified 2 years, 10 months ago by Bob Wight.
              #259541
              hondaatc
                Anyone have a part number of the john deere coil i found this one but not sure if its the right one thanks
                #259543
                  That looks to be the coil. This was posted
                  by MAS in 2014. I believe he was as successful.
                  Others have also attempted this but they
                  weren’t successful. You are not the first to be
                  looking for a solution to replace this coil as
                  it is often bad. If you do attempt this taking
                  pictures with explanations would be helpful
                  for others in the same position, if you succeed.
                  Good luck.
                  #259545
                  hondaatc
                    Yes definitely will take pictures and post part numbers if this works fingers crossed
                    #259580
                    seakaye12
                      This is interesting as I have a Lauson T600 Twin and it has an Eisemann 62D Magneto.    OP hondaatc’s Lauson Twin has a WICO?
                      #259591
                      hondaatc
                        Yeah i have two twins one has this wico ignition and one has the eisemann but thats lauson for u
