Home › Forum › Ask A Member › Looking for wico x8795 coil or possible replacement
- This topic has 28 replies, 7 voices, and was last updated 2 years, 9 months ago by
Bob Wight.
May 16, 2022 at 2:28 pm #259958
Received the replacement coil today installed and back in business
May 16, 2022 at 9:12 pm #259968Good to hear the pony coil conversion worked out.
"Every time you remove a broken or seized bolt an angel gets his wings."May 16, 2022 at 9:39 pm #259970Hi bobw this is an actual replacement for the wico coil from a business recommend in the comments very good to deal with
May 17, 2022 at 12:08 am #259974OK, read back thru your earlier post where you had ordered the Wico replacement. In your posted picture, the replacement looks very similar to a JD pony coil so guess I just got confused in a senior moment there!
"Every time you remove a broken or seized bolt an angel gets his wings."May 17, 2022 at 8:05 am #259975Ha its probably the same coil i wouldn’t be surprised
May 17, 2022 at 8:37 am #259978
It does appear that the 2 cylinder Wico magneto and
the John Deere Pony ignition use the same coil.
Tubs.
May 17, 2022 at 10:24 am #259982Yes; it sure looks the same. So; how about the Eisemann version. Is there a known replacement coil for the Eisemann 62D as used on a Lauson T600?
May 17, 2022 at 11:20 am #259987Standard magneto told me the the coil for a maytag twin model 72 will work i have not tried this out but I’ve been told by multiple sources it will work i have seen the coils for the maytag on ebay
May 17, 2022 at 1:40 pm #259989Yes; it sure looks the same. So; how about the Eisemann version. Is there a known replacement coil for the Eisemann 62D as used on a Lauson T600?
My ’37 Champion had an Eisemann 72B magneto. I found a replacement coil for it at Bob’s Small Engine Repair in Iowa (club member Bob Blin). You could also verify with him about the 72 coil fitting on your 62D magneto.
Another source for the Maytag coils is Mark’s Carburetor & Magneto. According to his Facebook page, he recently sold his operation to another party but they are still doing business with the new ownership.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
