Hey guys,
I need a water pump housing,clutch, prop,impeller, propshaft w gear, and a few other things for a WG4.
I believe the Merc KD4 is the same gearcase from what I read.
Id be happy with a good gearcase, sans driveshaft, if anyone has anything to offer, or just parts.
Thanks Vinnie
An impeller is the hardest and yet the easiest to find item on your wish list. A few years back Joe Brincat wrote a short article about adapting
a common inexpensive impeller to work on his WB3S.
Props live a hard life.
Look up prior questions along this line as kindly members have posted
Illustrated Parts Manual page showing ALL the parts that SHOULD be
in lower unit…Dollars to doughnuts prior owner/mechanics lost or left out small items they did not deem necessary. BAD MISTAKE, the entire lower unit is designed to work with all parts in place.
As a reminder when searching on this site: The SEARCH field on this page does not work. The SEARCH field on the FORUMS page works quite well. Or; use Google for your search. You can ask Google to return results ONY from this site by adding site:aomci.org after your search terms,
This reply was modified 3 years, 4 months ago by seakaye12.
It would be helpful to have this “pinned” at the top of the subjects (or in a “tips using this forum” sub-forum), so it’s always available!
