Home Forum Ask A Member Lower Housing Cracked 1957 Big Twin
Viewing 2 posts - 41 through 42 (of 42 total)
  • #12202
      The upper and lower gear housings are machined as a unit. The skeg casting was NEVER available by itself from the factory. A freeze crack usually occurs down by the 303358 pivot pin. A crack by the seam is usually the result of hitting something while being trailered.
      Hope this helps –
      #12215
      ray-schaber
        If the crack is visible you can groove it and fill with epoxy.
        Ray
