Home › Forum › Ask A Member › Lower unit
  • #918
    weedlessdrive
      what gear cases fit a 58 johnson 10hp to interchange? Are there some that cross fit
      Thanks
      #11942
        ’58 to ’63 Johnnyrudes will all interchange. I have used a later 9.5 gearcase on a ’59 Johnson QD after swapping out the drive shaft and pinion gear. 😉
        #11943
        weedlessdrive
          Is the 7 1/2 hp the same?thanks
          #11944
            The dimensions and gears are basically the same but the 7.5 has the shock absorber pinion shaft and the bushing ID is smaller than the ten horse drive shaft. Sorry, wont work.
            #12090
              Yeah, the 58-63 10hp gearcase is pretty unigue. The tough part to find these days is the driveshaft, the extra power was tough on the smaller gearcase when water got inside. Most 10hp driveshafts are worn in the lower bushing area, the lower bushings in the gearcase are usually whooped out as well. Complete 10hp gearcases will swap out from 58-63 but be careful trying to mix/match parts between different gearcases, the driveshaffts and gears changes around 1960.
              #12094
                quote fleetwin:
                Yes, there was a mid-year change in 1960 (QD-21 vs QD-21S) that I think changed the drive shaft from keyed to splined, and lowered the tooth count on the gears so they are beefier.
