Home Forum Ask A Member Lower unit gear oil 1948 Martin & 1956 15 hp evinrude
  • #220866
    trainsnmore
      I am looking for the proper lower unit gear oil to use for a 1948 Martin 7.2 hp and a 1956 15 hp evinrude outboard motor.
      Thank you all for your help in the past.
      #220881
      crosbyman
        wally mart outboard gearcase oil should do I have seen some 90 grade oil are marked…NOT FOR MARINE ENGINE USE so stick to marine stuff.
        #220884
          • This reply was modified 4 years, 5 months ago by Tubs.
          #220887
            Walmart has sae 40 “racing oil” by Valvolene. Don’t put that stuff in fuel mix though.
            #220888
              #220938
              hiram1914
                The Martin 60 (7.2hp) uses grease and not oil. If you have a Martin 75 (7.5hp) it uses SAE 40 oil. In the Martin 60 I use Lubriplate 105, but many folks on this forum speak highly of Cornhead grease, which I believe they said is made by or for John Deere.
                #220939
                crosbyman
                  interesting…..what is today’s advantage of grease compared with oils ? wouldn’t modern oils not lubricate properly or better than grease ?
                  #220941
                    • This reply was modified 4 years, 2 months ago by Tubs.
                    #220948
                    crosbyman
                      that answers the question…
                      2nd Q any harm in using it in gc with seals ?
                      #220955
