Home Forum Ask A Member LT 37
  • #292329
    Boonie
      Hi guys. Does a johnson LT 37  and an LT 38 use the same conecting rod?
      #292331
      MHarrington
        US Junior Member
        I was looking at the Johnson common parts list and it says they are compatible.
        This is the link for it in case you need it or future reference https://www.joeoutboard.com/resources/Manuals/Johnson/JohnsonCommonParts.pdf
        #292342
          Thanks M for posting that. I have a 1931 OA-55  that’s getting near the top of the list and it has some damaged and missing parts. Tubs
          #292343
            I suspect you have a connecting rod already, but incase you don’t, I know I have one from an LS. I’m not sure if it is good. If you do need one, I’ll find it and check it out. If it looks to be OK you can have if you need it.  Tubs
            #292346
            Boonie
              Thanks Tubs. Yes i do need it and possibly a piston as well. When i try to post a picture it says file to big. Cant seem to figure that out?
              Dan
              #292354
                Rod fit on crankshaft and wrist pin is good. Piston looks OK. What is you postal code. I’ll stop in at the post office next time I go into town and find out how much to ship it. Then you can decide if you still want it. Do you have a U.S. address I can ship it to? Tubs
                #292759
                Boonie
                  Hi Tubs Seems i made a mistake when i posted this thread. Im looking for parts for a KA 37. Not an LT37. Got my letters mixed up.
                  so still in need of connecting rod and piston with rings. Or can i buy new rings somewhere.
                  Sorry for the confusion.
                  Dan
