What is the small grease packet that comes with a set of points used for? One answer I found was to grease the inside rim of the mag plate??? I am not sure what that means and why would I be greasing the inside rim?
Tim that grease is for the rubbing blocks on the points. Helps to prevent pre-mature wear as they rub on the cam.
