Home Forum Ask A Member Majestic 7.8hp in need of….
  • #1049
    Michael Brown
      Fellas, I need a water pump impeller for my Majestic 7.8 hp probably a 1954-56 motor. Has anyone found a source/modification of existing etc. impeller that would work on this motor. 1/2" shaft 1,5/8" diameter and 5/8 " deep
      Many Thanks
      Mike
      #12939
        Have you tried Brian Wilcox? He makes new impellers on your old hub. email Baron0418@att.net please note the b must be a capital
        #12944
        mercuryman
          I have a 1956 7.8 Majestic and I used a Sierra 18-3008, it was a little fat and I sanded it some. Also you need to drill a hole for the pin that goes through the shaft. When I got through it pumped real good and I got 18.3 MPH on my test run.
          #12977
          Michael Brown
            Thank you guys Im on it.
            Mike
