Home › Forum › Ask A Member › Manual hydraulic hand pump tilt
- This topic has 17 replies, 8 voices, and was last updated 3 years, 1 month ago by
Asagodowns.
June 30, 2019 at 2:58 pm #178235
There was another one called LecoLift in the 1950s. It was a small thing mounted on the dash. It had a knob that was pulled and pushed to tilt the motor up manually/hydraulically. The oil reservoir/cylinder was a metal oil cup attached to the knob behind the dash. Two big brackets were on the rear of the transom attached to the motor.
July 1, 2019 at 8:13 am #178275Oh interesting!!!! I wonder if that is the one my friend had… the knob he had was much smaller than the one in the photo above. Either way, I love this concept of the manual lift… Now I seem to have two options to look out for! Thanks everyone!
Boats: '47 Dunphy, '64 Starcraft
Motors:
'53 Evinrude 25; '54 Evinrude 7.5; '55 Evinrude 7.5; '56 Evinrude 30 Lark; '56 Evinrude 16; '58 Johnson 18; '60 Evinrude 10; '64 Evinrude 40July 1, 2019 at 8:25 am #178278Thanks Dave – this is SUPER helpful. Does anyone out there see any reason why this might NOT work with a ’64 Evinrude 40 hp? Since it was used with merc, perhaps the setup might be different? I’m hoping it will work. So here’s my stupid question of the day… What do the haudraulic arms connect to? I’m assuming I mount something on the transom, but does anyone know what the other side connects to? I’m guessing it has to be something on part #72 in the diagram I am attaching… Thoughts anyone?
Motors:
'53 Evinrude 25; '54 Evinrude 7.5; '55 Evinrude 7.5; '56 Evinrude 30 Lark; '56 Evinrude 16; '58 Johnson 18; '60 Evinrude 10; '64 Evinrude 40March 10, 2022 at 8:51 pm #255977Dave do you still have Dole mechanical pump tilt?
March 10, 2022 at 8:57 pm #255978Sold
March 10, 2022 at 10:28 pm #255988A friend had a vintage 1950s Leco-Lift that operated a Johnson 35HP which worked perfectly. Small knob with oil cup reservoir behind the wood dash.
March 21, 2022 at 4:39 pm #256585Yes – I have it – never used it since it was for a Mercury and all my motors are OMC. I couldn’t figure out a way to make it work for me. So, if you are interested, I’ll be happy to sell it…
Motors:
'53 Evinrude 25; '54 Evinrude 7.5; '55 Evinrude 7.5; '56 Evinrude 30 Lark; '56 Evinrude 16; '58 Johnson 18; '60 Evinrude 10; '64 Evinrude 40March 21, 2022 at 7:48 pm #256606Had to go back and read thread again, so you ended up finding one?
I have the Dole Tilt on my 1977 Mercury 850 that came with BW Montauk 17 I just bought. Mine is in good working order, but shows corrosion on the hose fittings etc, was thinking could be a good idea to replace some or all of it.
