Home Forum Ask A Member Mark 75 fuel tank connections
  • #293961
    GLEN DEUTSCH
      Not sure if I entered this correctly the first time. I need the connectors on the ends of the fuel line that connects the tank to the engine.
      Glen
      #293975
      seakaye12
        If I go to MarineEngine.com and go to the Mark 75 Page it shows the part that you need as#22831Q3  or the Sierra equivalent #18-8069.  If you Google those numbers you will find all sorts of choices from OEM on down to Chinese knock-offs.
        Of course that’s assuming that all is stock on the engine side.
        As far as the fuel tank end of the line…..that would depend on what fuel tank you have.  Can you post a picture of it?
        https://www.marineengine.com/parts/mercury-mark-outboard-parts/mark-75/all/fuel-pump-and-fuel-lines
        #293984
        GLEN DEUTSCH
          Thanks Seakaye 12,
          That should do it. I sold the motor, so I do not have it to take a photo. The tanks are the old original tanks with the large aluminum L shaped connectors. You have been very helpfull, Thanks
          Glen
