quote david bartlett:
Tubs, I got some 40wt at Tractor Supply in a 2-gallon jug. If you come to Maine this summer I will give you what you need.
I saw that 2-gallon jug. My closest TSC doesn’t stock it.
One in driveing distance does but what was I going to do
with 2 gallons. I found 1 quart on eBay for the same $20.00
as the 2 gallon jug from TSC. twostroke just hooked me up.
with a quart. I’ve put all new seals in this thing but if I
should have to change it a lot and run out I’ll look you up.
