Home Forum Ask A Member Martin auxiliary fuel tank
  • #10206
    nlwildcat22
      Does anyone have a photo of a Martin auxiliary fuel tank?
      #77712
      RICHARD A. WHITE
        The Master Manual shows how to make the Martin 200 work with one, but shows no pictures that I could find….
        classicomctools@gmail.com
        #77713
          #77714
          amuller
            Interesting. Is that Master Manual online anywhere?
            I’m wondering if that tank setup in the pic is for continuous operation or for transferring fuel into the built in tank.
            #77716
            RICHARD A. WHITE
              It shows adding a fuel pump… I have an original manual, I do not know if it is online…
              #77718
              amuller
                Larsen sells a "master manual" for $60. Probably the same thing?
                #77719
                RICHARD A. WHITE
                  I would assume , probably a copy, if that even matters…
                  #77736
                  nlwildcat22
                    I have two 200’s. They both have an onboard fuel pump. I seem to remember that some of them don’t. Russ Larson has the tank-side fuel fitting, but I don’t know anybody who has a tank. (except maybe Tubs) It’s easy to convert to a J/E fuel fitting.
                    #77750
                      I only have pictures of this one and one other.
                      #143429
                      georgemartin200
                        I have many Martin 200’s, totally restored mechanically & cosmetically & test run. I also have many 200 remote tanks BUT I do not yet know how to post pictures. Also as they are so hard to find, (Harder by far than the motor itself), I do not have any for sale CHEAP as they are all nice, some nicer than the others, of course. Will see about posting a picture later.
                        Ronald
