Home › Forum › Ask A Member › Maxwell Tecumseh Canadian aka Spartan 5
Viewing 10 posts - 11 through 20 (of 23 total)
  • #77351
    bill-loveland
      quote Mumbles:
      OK, I was just over there but I’ll try and get back in the next day or two. One or two days wait shouldn’t matter if it took twenty years to ID this motor! 😀
      By the way, would you know of any Spartan 5 donor motors? The cracked inertia wheel on mine is holding me up from trying to start it.
      Is that a part you’d find on a lawnmower engine?
      #77353
        I don’t think so. The motor does have a small flywheel on top but this thing goes on the bottom of the crank and probably replaces the weight of a mower blade. It’s fairly heavy and might be cast of zinc.
        #77370
        kevinrude
          Hey Bill, if you look at the advertising provided by Mumbles, you’ll notice that there is a triangle labelled "4 stroke". Is that how the triangle on your tiller handle reads?
          #77372
          bill-loveland
            You’re close – one says "4 CYCLE" and another says "4 CYCLE SPARTAN". I could be convinced that my handle says "4 CYCLE SPARTAN".
            Mumbles, when you take a look at yours, see if you can read what your handle says.
            #77382
              OK, I’ll go over in the morning and take a peek. I’m curious to.
              #77472
                quote bill_loveland:
                I just looked at my Spartan and I can make out a 4 and Spartan inside the triangle cast into the tiller but the rest is kind of vague. It would need beading to make it any clearer.
                There’s no decal saying Maxwell anywhere on it but it does have an ID plate fastened to the front identifying it as a Lauson four stroke powerhead. This outboard truly is a ‘mower on a stick’ and going by the serial number, there must have been close to ten million of them made!
                bh
                  …long-time Canadian collectors thought it might have some connection with the Montreal Triton/Arrow motor, but I don’t think so now.
                  Bill; -did u klnow that our friend Doug Overbury was the Chief Engineer in Montreal @Arrow ? [bh/]
                  #77610
                  bill-loveland
                    I didn’t – was he at Tack’s?
                    #77612
                    bill-loveland
                      quote Mumbles:
                      Thanks Mumbles – I suspect the serial number reflects the number of engines made in all applications, not just outboard
                      Now to find somebody who can solve the "MAXWELL" puzzle. As it happens, I have a Canadian friend who is a Lauson (outboard) expert, as well as having a strong interest in lots of other mechanical things.
                      Would a junk Lauson outboard be a donor source of an intertia wheel?
                      #77622
                        I’m not sure but that’s a good idea! 💡
                        Without any schematics or Lausons in my pile, I don’t know what they are composed of.
