Home Forum Ask A Member Merc 110 Tiller Shaft
  • #172837
    slim60
      My ’63 Merc 110 has a broken tiller shaft. Can someone tell me how to change it?
      #172856
      Eric McNett
        which part of the shaft is broken? In the tiller handle or on the motor side.
        Eric McNett
        Seattle AOMCI Member
        #172859
        slim60
          It’s on the motor side close to the gear.
          #172973
          slim60
            Well, I was hoping someone would tell me this was possible without pulling the power head. There are two nuts visible under the pan. I should just get off the computer and do it tonight, look for parts tomorrow.
            #172989
              US Member - 2 Years
              I never had a white one but it sure looks to me like you are supposed to remove the tiller handle, take out one screw and withdraw the shaft out from where the tiller mounts….Looks to me like that gear next to the power head, and the shaft (they call it a “socket) it is attached to, stays in the cowl…
              http://www.marineengine.com/parts/mercury-outboard-parts/110/1470349-thru-1865778/steering-handle-assembly
              #173000
              20mercman
                I probably have the parts you need Slim. I am in Kenosha also, we met at the Silver Lake meet previously.
                Steve
                #173053
                slim60
                  billw; If you’re referring to part #19, I took it out and do not see what it does. If I could remove the upper shift rod the pan would slide back giving access to the nuts holding the tiller mount to the transom bracket. PH and LU are removed.
                  #173061
                    US Member - 2 Years
                    If it’s like some of my black small Mercs, (and it sure looks like it is) #19 is a single screw, who’s edge just overlaps the edge of a bushing. That bushing is part of the throttle shaft assembly, that should now pull straight out. Admittedly, sometimes that bushing can be a real fight to pull out. You can latch onto the “paddle” part of the linkage with vise grips and pry on the vise grips with a screw driver. #18, which seems to be the part you’re describing as broken, should pull out. You shouldn’t need to have to pull the pan or the tiller support bracket, which is a much more major operation.
                    #173128
                    slim60
                      Thanks billw. It pulled out. The end looks rough. Should it be square?
                      • This reply was modified 5 years ago by slim60.
                      #173139
                      dave-bernard
                        yes it is square
