Home › Forum › Ask A Member › Mercotronic 98
- This topic has 29 replies, 8 voices, and was last updated 4 years, 6 months ago by billw.
October 16, 2019 at 5:40 pm #185417
Okay, so I hate to ask all the same questions; but I just picked up a Merc-o-tronic Model 98, for the first time. (I have been using a Stevens.) Is there a user’s guide with manufacturer specs available? What is the purpose of the 7.5 V battery if it has a 120V plug? And I know I should know the answer to this by now; but what are you guys using for a battery? Thanks!
October 16, 2019 at 7:29 pm #185422It is here members only, inner sanctum, old iron reference, manuals
https://aomci.org/wp-content/uploads/2019/02/Merc-O-Tronic-ilovepdf-compressed.pdf
October 16, 2019 at 7:30 pm #185423The 7.5 volt battery was meant to be used for the coil power, coil continuity, and resistance tests. They require DC current. It can be replaced with a 7.2 volt rechargeable drill battery. The 120 volt AC circuits are meant for capacitor tests. Neither power will do all tests. I use a 7.5 volt DC wall-wart for my 98. R.T.
October 16, 2019 at 8:16 pm #185428you can get remote controlled RC toys 7.2 volt battery with charger on Ebay for $20.00 or less.
- This reply was modified 4 years, 6 months ago by dave-bernard.
October 17, 2019 at 5:21 am #185439The 7.5 volt battery was meant to be used for the coil power, coil continuity, and resistance tests. They require DC current. It can be replaced with a 7.2 volt rechargeable drill battery. The 120 volt AC circuits are meant for capacitor tests. Neither power will do all tests. I use a 7.5 volt DC wall-wart for my 98. R.T.
Thanks guys. So, I am assuming a wall wart is an AC/DC converter or transformer, like a phone charger or the like? Do we know the minimum amp output requirement for such a device? I understand the 7.5 volt part. I think I like that idea a little better than having a Chinese lithium battery in the house, for what little use it will get..
Edit: The most amps I see available on eBay is 2 amps. Doesn’t seem like much….
Boy, when you take the original battery out of the machine, there is nothing to it! I mean, my Stevens is about twice the size, has old glass tubes in it and is really built.
My 98’s dial plastic is a bit faded too. I was going to try headlight restorer on it. Any ideas there? Thoughts?
- This reply was modified 4 years, 6 months ago by billw.
October 17, 2019 at 5:51 am #185441It is here members only, inner sanctum, old iron reference, manuals
Now THAT’S A book! Thanks for that!
October 17, 2019 at 6:10 am #185443Okay, this seems to be a Ni Cad so I feel better. It has +5 amps and coil specs don’t seem to need more than 3. Maybe I am over simplifying; but I bought this one:
October 17, 2019 at 8:49 am #185444I am working on a conversion to use a 7.5 volt DC laptop power supply instead of a battery.
Quick and simple to install. The laptop power supply plugs directly into a connector like this.
https://www.amazon.com/2-1mm-5-5mm-Female-Power-Adapter/dp/B003MHUN7SMount this inside your case, connect the positive and negative wire that would normal go to the battery to this connector, then plug in the power supply like this: I will get the proper part number this evening.
And you will NEVER need to worry about an uncharged battery.
FYI… Mercotronic sold a unit as an accessory to do just this… I can post photos of their catalog to corroborate this statement, showing actually voltage and amperage of the unit.
Just not had time to write the article.
Respectfully
Richard
classicomctools@gmail.comOctober 17, 2019 at 10:19 am #185446- This reply was modified 3 years, 2 months ago by The Boat House.
October 17, 2019 at 10:39 am #185448If you use a battery you don’t need plug in and can do it at the dock.
