Home › Forum › Ask A Member › Mercotronic 98
The Boat House wrote: This is the power supply I’m using. https://www.ebay.com/itm/POWERNEX-MEAN-WELL-NEW-GST40A07-P1J-7-5V-5-34A-40W-Industrial-Adaptor/252631122873?hash=item3ad1fd03b9:g:AzcAAOSwImRYJTS~
That is the one…. Thanks Tubs
http://www.richardsoutboardtools.com classicomctools@gmail.com
https://www.enginads.com/otto/
Cool set up indeed! Now you have two AC plugs, correct?
Dave, if you employ only the power supply, all of the tests are not available. The capacitance test will not work. It requires an AC signal. R.T.
The laptop power supply is a great idea. I might even have one of them kicking around. I never realized they were 7.5 volts. I always just assumed they were 12 or 5. Thanks for all the input!
They are all NOT the same… be sure yours is 7.5 DC volts
