Home Forum Ask A Member Mercury 110 (9.8) year?
  • #287264
    bunky
      I picked up another Mercury 110 9.8hp and would like to figure out what year it is so I can order some parts…   the tag has been removed..
      The motor has a blue band, HEI ignition with red coils or covers.
      I looked where others in post have said to check   like on the head and block area by the word lightning. But no serial number there…
      #287266
      dave-bernard
        blue is 72 and up area
        #287267
        crosbyman
          from early 70s upward  Merc was evolving to electronic ignition ex: with stator CDI  ignition under control of a trigger coil ( no mechanical points) .
          around mid 70 they had  phase maker ignition a bit of a mix  of CDI  and points  MAKING contacts to fire the points. Normal magnetos usually OPEN their contact surfaces to generate sparks but PHASE MAKER  closes the points to fire.
          here is a good read on Merc ignition  by M.Mohat
          https://wrcoutboards.org/wp-content/uploads/2021/02/The-Phase-Maker-CDI.pdf
          https://wrcoutboards.org/wp-content/uploads/2021/02/Generator-Coils-Explained.pdf
          #287274
          bunky
            Thanks for the responses
            I believe I do have the phase maker ignition..  I think there’s a sticker saying this…
            Thanks again
            #287276
            crosbyman
              seakaye12
                Sometimes the serial number is on the TOP of the block….over by the Exhaust Port….back almost under the flywheel.  Very faint Look there also.
                I have attached some cowling pics.  Once you determine what the year most likely is….you can determine the serial number range from the chart.  Mercury parts are sold by serial number;  not year.
                #287284
                bunky
                  Here’s a picture of the engine
                  #287286
                  seakaye12
                    It’s best to never use the stop button to shut that vintage of Mercury down.  Choke it instead.  Also;  never rope it over with the spark plug wires disconnected.
                    #287301
                    crosbyman
                      new impeller , carb job  and GC oil  with  some  masking tape and Mercury black  and it will look brand new !   dirty  phase maker points are  not so worrysome it semms …. see article
                      #287309
                      seakaye12
                        They are great motors if they have been maintained.  Check for leaks/water intrusion in the lower unit.  Hopefully you  have spark.  Ignition components on those are expensive and can exceed the value of the motor.
                        It’s always best to work from a serial number.  It’s probably on the block somewhere;  you just haven’t found it yet.
                        The pic attached shows another location for the serial number.
