Home Forum Ask A Member Mercury Bendix Scintilla Condensers
  • #284915
    Francis Cyr
      I am looking for a condensers for my KG7.  The Bendix condensers in it are shot (leaking).  Coils are new.  Is there a common inexpensive condenser I can use that tests at .17-.21 microfarads?  Thank you.
      #284917
      crosbyman
        Canada Member - 2 Years
        strickly from a uf point of view there are very common .22uf cap. available
        at .22uf  such a small difference  should not cause a problem  compared  to .17uf-. 20uf caps
        if they fit…                     you also have small ceramic caps   you can wire in.
        I have never workeda kg7 but caps are caps  and if they fit they should work.  you can even rebuild  them see article by M.M.Mohat
        https://wrcoutboards.org/wp-content/uploads/2020/04/Part4_Repairing_Broken_Condensers.pdf
