Home Forum Ask A Member Mercury flywheel nut removal tool
  • #253498
    green-thumbs
      US Member - 2 Years
      OMC “Universal” coils.
      Before you start, mark which side of magneto plate each coil lamination stack goes where. May or may not make a difference, but, why take chances.
      Louis
      Coils that look bad can be good and coils that look good can be bad. If the coils test good, it may be possible to repair insulation. New or good used OMC universal magneto coils are low cost options.
      #253538
        If you have any good ones laying around it
        wont cost you anything. Also sometimes you
        wont get a spark right away. If that is the case
        spin the motor with a drill, with the spark plugs
        out, grounded to the motor, and the spark will
        soon appear. You can also accomplish the
        same thing by just pulling it over but it takes a
        bit longer.
        A "Boat House Repair" is one that done without having tools or the skills to do it properly.
