Home › Forum › Ask A Member › Mercury K1? Or maybe not?
Viewing 10 posts - 21 through 30 (of 30 total)
  • #195110
    opposedtwin
      Kirk, you are correct. That’s what I was referring to. After re-reading it however I realize Louis was referencing the legs in the many pics you all posted. Also thanks for the additional pics.
      While I’m waiting for the flywheel and sheave to arrive, I removed the magneto from my k3 model and installed it on the sea king. Save for the spark advance lever, they appear to be the same. I will have to go through the carb still in order to make it run but I’m one step closer.
      I took a green pad to the top of the crank shaft today and there is some rust that didn’t disappear. But most of it did! Do I dare take sand paper or emory cloth to it? The crank case does turn easily and it looks very clean inside.
      Scott
      #195114
      kirkp
        Louis or others will chime in but I believe these early Mercs share components. Don’t know if you already have it but I’m attaching a parts list for the early models.
        I don’t think taking some emory cloth to clean up the crank will be a problem as long as you don’t go crazy.
        Out of curiosity have you checked the compression? You could probably double nut the crank threads and use a drill to turn it over.
        Kirk
        #195117
        opposedtwin
          Kirk
          I haven’t checked compression with a gauge as I rarely do on small pre-1950 motors. Turning it by hand it seemed to have pretty good bounce.
          I do have some of the old charts that list parts. Turns out K1/K3 share many parts! I can use the flywheel and mag from my k3 to keep moving forward.
          Scott
          #195118
          opposedtwin
            So the carb is simply a fuel/air mixing valve, correct? What needs to be done to “go through” it? It looks really clean inside. Not really sure how one works. What is the function of the hole-filled chamber on the bottom? I’m assuming that’s where air is sucked in mixed with the fuel being metered by the single needle out front?
            • This reply was modified 6 years, 9 months ago by opposedtwin.
            #195143
            kirkp
              Scott, you are correct that it is a simple mixing valve. Yours with all the holes is a new one to me but maybe someone will know what’s going on. Here’s a pic of the valve on my Sea King. Turns out the manual I have is too big to attach. Here’s the first two pages so maybe you can see if it’s different than what you have. If you want me to send it to you, send me an email.
              Kirk
              100_2261
              manual-1
              manual-2
              #195152
              green-thumbs
                Share and share alike,,well yes and then again no. The single cylinder
                models rapidly evolved. Amazingly, almost all improved design parts can be back fitted to earlier design. All are the same, but, all are different one way to put it. Between the two years there are fundamental changes in design. Within the two years there are variations in details.
                In tearing down a 1941 KB3 Mercury, I damaged the crankcase, a friend had given me a 1941 Sea King less tank and magneto,,,an easy swap. A friend had a 1946 WD3 with a damaged tower. The Sea King tower was the same and worked just fine. It started, ran and pumped
                like a fire engine. BUT, Kiekhaefer postwar Mercury and Wizard models began to have frustrating difference for parts swoppers,
                Louis
                #195156
                John
                  Actually, that “carb” is a bit more than a simple air/fuel mixing valve. It contains a spring loaded poppet valve that opens and closes with each stroke of the piston. You will note that your motor does not have any reed valves. The poppet performs this function. When the piston moves down in the cylinder, it pressurizes the crankcase, and forces the poppet closed. On the piston’s up stroke, the resulting vacuum in the crankcase lifts the poppet off its seat, allowing air (which mixes with fuel metered by the needle valve) into the crankcase and allowing fuel past the needle valve. You will see that the opening for the needle valve is in the beveled seat for the poppet so that a closed poppet also stops fuel flow. You will be able to hear the poppet clanking on the seat, while the motor is running. These contraptions work surprisingly well.My 1941 Sea King with poppet starts easily and runs smooth. However, you won’t win any races with that motor. You will probably find that you need to adjust the needle valve for best operation as you move from idle to high speed operation, and vice versa, as there is no separate idle circuit.
                  Kirk’s picture of the bottom of the valve shows a pin and screen. These also perform a function. To start a cold engine, push up momentarily on the pin, which lifts the poppet and allows a bit of fuel to flow past the needle. This fuel will wet the screen, acting to enrich the fuel/air mix and thus prime for cold starting, since there is no choke on these motors, either.
                  John Van
                  #195295
                  kirkp
                    John, great description of the operation. Any thoughts on the setup that Scott has?
                    Kirk
                    #195717
                    opposedtwin
                      I substituted the magneto from my K3 and now (along with the flywheel and sheave Bob supplied) I have a good spark on the sea king.
                      In the disassembly/assembly I lost track of where the little wave washer goes. Is it underneath or on top of the cam?
                      I need to clean the tank and get fresh gas to the motor and hopefully it will run.
                      Scott
                      #195768
                      kirkp
                        Scott, sent you an email
                        Kirk
