Home › Forum › Ask A Member › Mercury KB-1A gas tank leaks
  • #272267
      I thought I’d rinse out the gas tank on the subject motor before
      I reinstalled it. It leaked like a sieve around the center seam.
      I managed to get the two halves separated, and studs removed
      without much problem. There was no sign of it ever having
      a gasket (unless it’s been apart before), but rather some kind
      of seam sealer, that was hard, and broke apart in a thousand pieces.
      I got the tank sandblasted inside and out, but still need to lap the halves
      if I can a piece of glass around big enough.
      Should I make a gasket, use a magic sealer, or both?
      I may have some SealAll sealer, and if that doesn’t work, a little
      Kreem gas tank sealer to slosh around.
      What has proved successful for you?
      Thanks.
      DSCN6019
      DSCN6018
      green-thumbs
        To lap the tank you will have to remove the studs. Treat the studs carefully. If stuck they will snap off flush to surface. Been there. done that, and don’t care to go back. When lapping it helps to coat the surface with layout dye or felt maker to show high and low spots as lapping removes metal.  Takes time and effort, but, results in a flat close fit that clamps the gasket equally at all points.  4 fastener tanks may be more demanding than later 6 fastener tanks.
        Good Luck
        Louis
        #272282
        ROBERT LAFAYETTE
          Nobody makes a fuel proof
          sealer? Only fuel resistant.
          I just did a Sea King cast
          tank. I used Permatex
          Motorseal “ fuel resistant”
          I have not tested yet due
          to cold weather.
          another option I might
          Try is JB weld, buy  the big
          size.
          Good Luck,
            Good Luck
            Louis
            Louis, as seen in my first photo, the studs are already removed.
            I had to heat two of them, but none came out super hard.
            One tank I lapped a few years ago, I had glued two sheets of sand
            paper onto a piece of glass, which worked pretty good……
            it may have been your idea perhaps.
              to cold weather.
              size.
              Good Luck,
              Bob, I’ve never heard of the Permatex Motorseal sealer.
              I’d probably have to order it online.
              It makes you wonder what Mercury used for a sealer back in 1941???
              It must have held up pretty well.
              I guess Gasoila sealer is pretty good fuel resistance. I used it on a Flambeau
              once, but it cost a lot, and doesn’t have a very long shelf life.
              green-thumbs
                One not so obvious point…install the studs to same depth as they were…otherwise you wind up with very little thread for nuts and washers.
                Louis
                #272292
                  Louis
                  Good tip, Thanks Louis!
                    I took a KD3 tank to an automotive machine shop, years back. They surfaced the halves on their giant, foot-wide, horizontal belt sander, used for truing up cylinder heads. It took him five minutes, tops, and he charged me twenty bucks. But it would have taken me HOURS of aggravation, so it was a win-win for the tech and for me. I used anaerobic sealant, like for a crank case, on the flanges. It worked long enough for a successful, hour-long boat ride, then the tank was drained, the engine pickled and it was on to the next engine. I don’t know if the sealant would work indefinitely, or not. I have also made thin gaskets for those tanks, which is very tedious, but worked to seal it.
                    #272305
                      Bill, I’m “in the sticks”, so to say, so I won’t be looking for an engine machine shop.
                      I’ll check the tank halves with a straight edge first, and hopefully a little lapping
                      will suffice……. one can always “hope”!
                      However is seal the halves, I may just slosh some Kreem around in the tank afterward
                      for “good luck”.
                        For better or worse, but hopefully better than it was,
                        I lapped the tank halves today, and sealed them with
                        Seal-All, which was the best thing I had handy,
                        and will slosh some Kreem gas tank sealer around in
                        it tomorrow.
                        I barely had enough “spray on” adhesive to glue down
                        the four sheet of 100 grit sandpaper onto my window glass.
                        The top half of the tank lapped down in about 5 minutes,
                        the bottom half took over 1/2 hour, but that was including
                        the time it took to repair my air hose after the end blew off….
                        that’s always exciting!
                        DSCN6020
                        Getting there. The front of both halves seem to be the lowest,
                        for whatever reason.
                        DSCN6022
                        The studs seem to all original, and I even put the long ones
                        in the rear like I was suppose to.
                        DSCN6025
                        I found some copper washers that I used under the nuts…. it
                        had no washer before.
                        DSCN6026
