Home Forum Ask A Member MERCURY KD-3 WATER PUMP
  • #196492
    opposedtwin
      Thanks for that! I got the cover removed. It is indeed a sixteen square hole case with the oscillator type water pump. Now having trouble removing the small pin holding the eccentric to the prop shaft. Getting there a little at a time.
      Do you happen to have the text for that plate showing the numbered parts?
      Scott
      #196503
      fifty20ne
        comet9
        http://pub9.bravenet.com/photocenter/album.php?usernum=737212788&album=49067#bn-photocenter-1-1-737212788/49067/1/
        https://drive.google.com/file/d/0B6wRLMxPeVaiOWIxNDRkZWItOWRjMC00YTJhLTg3YWQtNDU3OWY2ZjRjZjlh/view
        On this site under “Technical – Discussion & Videos”
        I downloaded Mercury factory training charts and the instructions for the KB-1 Comet which uses the oscillator style pump.
        Don’t forget to remove the small cir – clip part # 73 from the brass eccentric cam! be careful not to lose??? they go flying!
        I tap the drive pins out with a drift pin and make new ones from K & S brass rod available from Hobby Shop or good hardware store.
        K3
        • This reply was modified 5 years, 1 month ago by fifty20ne.
        #196564
        opposedtwin
          Thanks Bob! Funny how that info sheet for the K3 describes the water pump as a rotex style when it’s actually an oscillating style!
          Do you happen to remember the diameter of the rod you buy at the hobby store to replace the pin?
          • This reply was modified 5 years, 1 month ago by opposedtwin.
          #196591
          fifty20ne
            K & S Metals
            K & S Engineering
            3/16 = .1875 “ solid brass rod
            K&S Solid Rod 3/16″ D X 12″ L Brass Carded https://www.amazon.com/dp/B00FG1M0MY/ref=cm_sw_r_cp_api_i_4yYxEbNFGPSYG
            #196637
            green-thumbs
              US Member - 2 Years
              It seems to me that you are referring to the 2nd type (brass eccentric cam) I believe the K3 would originally have had a 1st type (iron oscillator cam) If so, there is an internal pin in the oscillator cam, To remove this pin, after removing the sheer pin (which drives the propeller) raise the oscillator cam up the prop shaft so that pin aligns with holes in oscillator cam and push pin out. There should be a spring between sheer pin and end of oscillator cam to prevent cam from moving up shaft during operation.
              If memory serves the sheep pin is 3/16″ and the oscillator drive pin is
              3/16″ .Both pins can be made from 3/16″brass rod using a file and small vise.Getting length right on internal pin is a fit and try, Sheer pin
              Finding brass rod can be a now you see it and now you don’t proposition. .I bought a 3 foot length of 3/16″ at Lowes and have not
              see it there since..I was at Tractor Supply and found one 3/16″
              brass rod in the rack…It appears that both stores do not restock when
              sold out. Cutting brass rod to exact length can be tricky,,,,best to cut
              a little long and file to fit. Sheer pin can be fit to length of slot
              inside hub or propeller, same rounding of ends and reduction
              of diameter applies.
              Servicing a water pump usually involves making replacement pins,
              3/16″ brass rod may also be used to make High Steed needle for AJ
              series carburetors and an assembly tool to hold rod cap in place with
              the needle bearing steel rods
              Measure from end or rod to cutting wheel for length, the cut end(s) will be slightly thicker. Chuck in poor man’s lathe (electric or manual drill) to round ends and reduce the raised diameter.
              Louis
              • This reply was modified 5 years, 1 month ago by green-thumbs.
              #196641
              fifty20ne
                I learned something new
                Today! 1940 oscillator
                Cam is different than 1941
                Wizard WB-3 that I worked
                On last year. The 1940
                Cam is definitely steel.
                I don’t know to remove
                Retention pin that is
                Parallel to prop shaft?
                Lou, please advise.
                Thanks,
                opposedtwin
                  Bob, the retention pin is perpendicular to the prop shaft. It goes through both the eccentric and the prop shaft. Just got mine out just before dinner. I was tapping the “pin” back and forth with a drift set and decided to add some heat. Removed the impeller and after a short heat up period, it started to move considerably faster. The pin must be brass because it’s beat, crooked and junky. Now it’s on to clean up, make a new gasket, lubricate and reassemble!
                  Keep at it, you’ll get it out.
                  I believe my eccentric is steel. It’s from my 1940 K3.
                  Scott
                  #196677
                  green-thumbs
                    US Member - 2 Years
                    I learned a few things too…I have had several of the 1940 16 square
                    hole pumps apart and never realized the purpose and need for the
                    spring on prop shaft I also learned not to trust memory…verify by checking part or reference source.
                    NOW for something to ponder,,,I have been told by a very reliable
                    source that the brass eccentric cam may be used in place of the iron
                    or steel eccentric cam. I have not figured out how the grease seal
                    can be made to function with such a substitution. I suspect some clever reengieering is called for
                    Louis
                    #196745
                    opposedtwin
                      Louis, when you say “substitution” you mean swapping a brass eccentric for a steel one? Can you post a picture of a brass one? Is it the same design as the steel one?
                      So there are no lip-type seals in this gear case, correct? Is the bushing around the prop shaft the only thing preventing water from getting into the gears?
                      Scott
                      #196759
                      green-thumbs
                        US Member - 2 Years
                        16 square hole water pump casting has string packing inside base of
                        iron oscillator cam I believe original to 1940 models
                        7 slit water pump has a thin wall cup with the packing inside, this fits over a lip in casting I believe original to 1941 models and some early postwar models
                        3 slit water pump (common to most postwar models) has a metal
                        case lip type seal pressed into casting.
                        ANY pump assembly will work with any model or year so substitutions
                        can and were made, Kiekhaefer offered a kit to convert to the
                        3 slit vane type pump. Kiekhaefer sometimes used old stock parts
                        Photos show a 7 slit water pump, brass oscillator cam, end in view of
                        oscillator cam with copper packing cup inside and a view of pump casting showing copper packing cup in place
                        The groove around the brass oscillator cam is so a short pin can be
                        held in place by a spring in groove…used when a sheer pin is used
                        to drive propeller. When clutch is used the spring and short pin are
                        not used, Instead a longer pin engages the front plate of the clutch
                        and the rear plate engages the propeller,
                        The iron and brass oscillator cams are different designs, BUT, the
                        prop shafts are the same on ALL versions from K1 to KE3 and
                        Wizards from WA2 to WG4 as well as both Sea Kings. Kiekhaefer
                        planned ahead for both rotax style pump and the clutch. All that
                        is needed to convert from oscillator type pump to a rotax vane
                        type pump is 1) 3 slit water pump housing 2) impeller drive hub
                        3) vane type impeller The rest can be transferred from the oscillator
                        type pump. The 3 types of water pump are completely different
                        but share some parts and are interchangeable as asemblies.
                        A design philosophy that was good for manufacturer, dealer
                        and customer.
