Home › Forum › Ask A Member › Mercury KD4
- This topic has 139 replies, 16 voices, and was last updated 3 years, 11 months ago by
Boonie.
December 29, 2020 at 8:25 pm #226332
Hey everyone. This is my first time posting on this site. I am curently restoring a Mercury KD4 and i need some help with ignition coils. How to test if they are any good and if not, help finding replacements?
December 29, 2020 at 9:45 pm #226343Mercury KD4 (early) had Eisemann 72H magneto ignition system
Bendix Scintilla magneto ignition systems were used on later KD4
The magnetos are entirely different with no parts in common.
SO,,,first order of business is to find out which magneto is on your KD4.
and report back.
Magnetos are not my strong point so hopefully some one will share
a little know how with us.
LouisDecember 30, 2020 at 5:28 am #226352It has been my personal experience that the Eisemann coils always work and the Bendix ones never do, at least on Mercurys. (Why they seem to be okay on Champions I have had, I have no idea.) The Bendix coils are held in place with snap clips, while the Eiesmanns are held in place with screws. That is a quick visual ID of what you might have.
December 30, 2020 at 7:55 am #226355They are bendix coils
December 30, 2020 at 8:44 am #226360December 30, 2020 at 8:49 am #226366December 30, 2020 at 9:01 am #226373MERCURY PARTS/PRICE LIST LINK.
December 30, 2020 at 9:29 am #226381Thanks Bob. Could be a problem finding replacements!
December 30, 2020 at 11:13 am #226390They are bendix coils
Well, all is not completely lost yet. Are they all cracked and disintegrating? Best not to try to use those. If, by some miracle, they are NOT all cracked, they MIGHT still work. Next steps would be to remove and CAREFULLY disassemble the points, and clean the contacts to like new condition. I say, “CAREFULLY,” because there are a lot of tiny little parts. Make particular note of where the tiny insulating bushings and washers go. Do one set at a time and make a drawing and/or take pictures of them, as you take them apart. Once the points are clean, ( I use 320 Emery cloth, changed frequently as the points are a very hard material.) reassemble them as you found them. Then, set the point gap at the high point of the cam. Somebody correct me if I am wrong, but I believe the setting is .020″. Now, with nothing connected to the points yet, connect an ohm meter to a point terminal and to the base plate. Turn the engine slowly by hand. On your meter, you should see the reading change between OL and LESS than 0.5 ohm. Preferably, ZERO ohms. If this is not the case, go back to something you did wrong with cleaning, reassembling and installing the points.
The condensers will definitely be bad, unless somebody has changed them recently. I like to use whatever automotive condenser will fit in its place. I used to have a NAPA/Echlin number in my head, but not at the moment. When you have new condensers, hook them and the coils, to the points, install the flywheel, pull the engine over rapidly and check for spark. A Bendix mag is absolutely STELLAR if it will even jump a 1/4″ gap. 3/16″ is more realistic. An old spark plug can be made into a checker, by opening the gap on the plug way up. Godspeed.
December 30, 2020 at 11:42 am #226394I found some coils on http://www.oldmercs.com
Product code 399-125.
Can anybody have a look and see if they think they will work on a kD4 Merc with a Bendix Scintilla mag. -
