Home › Forum › Ask A Member › Mercury KD4
- This topic has 139 replies, 16 voices, and was last updated 3 years, 11 months ago by
Boonie.
January 1, 2021 at 7:35 pm #226740
Peter McDowell at North York Marine will have your Mercury paint.
"Every time you remove a broken or seized bolt an angel gets his wings."January 1, 2021 at 7:50 pm #226741I have used the dull aluminum for my Johnson projects from NY marine. It looks great but it has a fleck to it and it is quite shiny. Much different than the original Merc colour.
January 1, 2021 at 8:59 pm #226758Perhaps his Mercury dull aluminum is a different formulation from his OMC dull aluminum. Don’t know for sure, as I don’t do Mercurys.
"Every time you remove a broken or seized bolt an angel gets his wings."January 2, 2021 at 5:30 pm #226807Talked to Peter McDowell today same dull aluminum used on both Johnson and Mercs. Checked the compression today top cylinder is 110 lbs and bottom is 80lbs. There is no play when the pistons are in the middle of thier stroke but when they reach tdc and switch to thier downward movement there is definately some play-slop for lack of a better term. In other words the crank will move slightly before the pistons start to move. Also seems to be some resistance turning the crank with the plugs out. Do these things seem normal?the resistance almost feels like a bad crank bearing?
January 3, 2021 at 8:53 am #226879.
January 4, 2021 at 11:59 am #227009Where would I even start to find rings for this old motor?
January 4, 2021 at 1:03 pm #227011First,
check with a ohmeter from 3k to open from ground to spark plug to test the secondary windingsJanuary 5, 2021 at 9:35 am #227067.
This reply was modified 4 years, 1 month ago by
Tubs.
January 7, 2021 at 5:32 am #227154Happy New Year,
I sent you a private message as we have the new piston rings on-hand. We can help with many other parts for a KD4 or most any vintage Mercury (and a growing amount of Evinrude and Johnson) as well (our family marine business turned 65 years old as a corporation yesterday, and is 70 years old since it’s founding this year – all the while with boats, outboard motors, and such).
Thank You,
JoeJanuary 7, 2021 at 7:47 am #227157Two coils are on Ebay Military Surplus Coils 13206E140 $14.50 & 9786E128 $24.50 Both work great , must make small mod to spark connection
This reply was modified 4 years, 3 months ago by
mercuryman.
