Home Forum Ask A Member Mercury KD4
Viewing 10 posts - 71 through 80 (of 140 total)
  • #229389
    fifty20ne
      KD-4 Chart
      Chart8-1
      #229445
        Bill the clutch is not driven by the impeller pin the 2 holes are outside the pump.. one for the clutch and one for prop without clutch as I have said ..
        This is a KD3S. If I am not mistaken, the KD4 is the same?
        #229481
        green-thumbs
          US Member - 2 Years
          Parts Illustration above shows only 1 pin. Which is correct for those
          models that have the rubber biscuit clutch.
          Certain models did not have the clutch. They used a shar pin in the
          rear hole in the prop shaft and a short pin in the impeller drive hub
          that was held in by a circular spring in the groove around the
          impeller drive hub or eccentric cam.
          Note that the clutch can be left out and a sheer pin used
          on all models IF a short pin and spring are used to drive hub or cam
          That requires the spring to retain the pin.
          Simple ingenious either or design provided all the right parts are
          in place. It is worth noting that prop shaft is same for all modes
          from `940 K1 thrue WG4…regardless of brand, single or twin, clutch
          or shear pin or whichever water pump.
          Louis
          Note: the 1940 16 square hole water pump had a more complex way
          to drive and retain the water pump oscillator cam. Used same prop shaft. 1941 7 slit design was modified as above. Propeller was
          changed to allow for either clutch or shear pin drive..
          • This reply was modified 4 years, 2 months ago by green-thumbs.
          #229500
          Boonie
            Good information. Thanks
            What’s the call on the flywheel? I’m not painting the flywheel but what about the, well not sure what it’s called. The pull rope goes around it. Paint it dull aluminum? I’ll post a pic.
            #229502
            Boonie
              Thinking on polishing the flywheel and painting this part?
              #229926
              Boonie
                All cleaned and primed ready to paint!
                #229930
                labrador-guy
                  Loo-ken good! Now the fun part starts. When the nice clean parts go together maybe some new parts you can see some progress being made. Don’t forget to make the screw heads look good.
                  Love it!
                  dale
                  You don’t need a parachute to skydive. You only need a parachute to skydive twice!
                  #229933
                  Boonie
                    Screws are already polished. Just trying to decide on a paint. I have some dull aluminum from NY marine. Doesn’t match the original. My plan is to leave the prop in original condition which is pretty good. Maybe I should try to match that paint? Any input is appreciated.
                    Dan
                    #229938
                    opposedtwin
                      Here is the paint many have used with good results!
                      3DADE8C5-31E8-4334-BBE3-C323E219F237
                      3EFEE194-9647-42BE-A1B8-3F5CDAEF5620
                      #231108
                      Boonie
                        I would like to remove the screw portion of this clamp to blast and paint. How can it be removed and replaced?
                        3F591EEE-76ED-4622-B4C1-04AA4B47C95F
