Home Forum Ask A Member Mercury KD4
Viewing 10 posts - 81 through 90 (of 140 total)
  • #231111
    opposedtwin
      The handles? I would just tape them up real good and leave them in.
      #231112
      Boonie
        Ya I think I will do. The reason I ask is because a couple of projects ago I got some sand in the threads and it locked up like it was welded!
        #231146
        green-thumbs
          US Member - 2 Years
          I have avoided messing with clamp screws except
          to free up those that are rusted tight.
          Heat and wax work surprisingly well
          Louis
          #233135
          Boonie
            Ok,so finishing up this KD4. Ran into a couple issues. When I put the flywheel on I am unable to adjust the points. They won’t move. With the flywheel off they move in and out. I have gone thru everything, I think.
            Also ready to put decals on but something doesn’t look right.
            #233152
              Can’t you adjust the points before you put the flywheel on?
              DAN UMBARGER
                Are you sure those aren’t KD3 decals?
                #233164
                Boonie
                  No the cam is part of the flywheel.
                  #233165
                  Boonie
                    Well I ordered KD4 decals. The ones with the red are kd3 but count the lines on the other two. Is that an error?
                    #233173
                    Boonie
                      Solved the points issue. Human error putting them together after cleaning!
                      #233221
                      Boonie
                        So KD4 is near completion. Just need to finish the plug wires and put the badge on it. I left the prop original and I am thinking on doing the same with the badge. Maybe steel wool the badge and clear it. Any thoughts?
