Home › Forum › Ask A Member › Mercury KE4 Ignition
- This topic has 18 replies, 9 voices, and was last updated 7 years, 8 months ago by
goldmember.
December 17, 2018 at 12:06 am #160357December 17, 2018 at 6:53 am #160398
If the coils are cracked, they may spark but when warm from running may fail.
December 17, 2018 at 6:55 am #160399I have two of those. Buzz Lindberg (“creekrunner” here) has a neat way of adapting them for the scintilla mags.
December 17, 2018 at 8:41 am #160414I used 2 of those in a Chriscraft Challenger. Good hot blue spark.. The output was in an awkward place, but some liquid electric tape solved the issue. I have photos but they are on my phone right now.
classicomctools@gmail.comDecember 17, 2018 at 11:23 am #160426No one agrees with me but you can coat them with Super Corona Dope, a very high voltage insulation that looks like clear finger nail polish from MG chemicals. Once the cracks are filled wrap with radio controlled airplane very thin fiberglass cloth & recoat. What is the resistance from plug wire to ground? Once the coil is clean look for pits where the coil may have arced to ground. There is two coil windings, primary &; the secondary winding, the wire used is finer than a humane hair & damaged easy. Running without having the plug wire off the spark plug has produced energy & will arc to the magneto plate.
Also don’t forget the capacitors, they fail too & will not give a good spark. They are 2 pieces of foil separated by wax as an insulator. The wax shrinks with time & shorts out the foils.
Top seal may be bad blowing fuel on the magneto causing no spark too, was it wet?-
This reply was modified 7 years, 8 months ago by
jeff-register.
December 17, 2018 at 8:37 pm #160528I get 3.2 on the primary for both and 5.7 on one secondary and 7.2 on the other secondary. I like your idea for the coils but it would be nice if someone could tell me if my readings are good or not. I don’t want to go through all of this for bad coils.
How do you test the capacitors?
December 17, 2018 at 8:46 pm #160531Great. How would I find that?
December 18, 2018 at 11:12 am #160618Capacitors are challenging to test without an ignition tester like a Mercotronic or Stevens. You can do simple tests with an ohmeter; test for a direct short (shouldn’t be shorted of course…) and then you can test with an analog meter and watch for just a bit of a bump of the needle on the 1k resistance scale. The needle should deflect just a bit and then return to rest. But these are simple basic tests that cannot indicate a cap which will fail under load. Usually they are just replaced if suspected bad.
I have resisted answering your question about the variance in the secondary resistance. I would think they should be the same if they were the same brand/vintage/model of coil….but I have seen many instances where coils will vary like that and still work. Like I stated in my first post here….if it were me I would clean things up and try running the motor or just do a spark test. Simple, quick and informative. If this is a motor that you want to build to be a daily runner then you will most likely want to replace coils, condensers, wires and points as the budget allows and parts become available.
CHUCK.
December 18, 2018 at 8:54 pm #160685Thanks for your help. I will do just that.
