Home › Forum › Ask A Member › Mercury KE4 Pull Start
  • #162661
    goldmember
      Is it possible to replace the pull rope without taking the whole thing apart?
      #162688
        Yes , take the 3 bolts out and remove the cover plate and paws. then the cable. NOTE check for rough areas especially where it goes through the tank. use the newer type rope not the cable type which is hard to work with.. 1 914 310 7086
        #162715
        kirkp
          Interesting comment Dave. I’ve been messing with the recoil on my KE3 and it has the wire cable. Haven’t measured it but I would bet it’s not much bigger than 1/8″. What size newer type rope would work?
          Thanks
          Kirk
          #162719
          dockbuster1
            The cord that was used on the two cyl Mercury four horse 79 80 Gnat will fit and work well
