Home › Forum › Ask A Member › Mercury KE4 Tillotson Carb
I have just re-assembled a Tillotson AJ23A carb after rebuilding and I was hoping you guys could tell me if I got it right.
Looking from the top down, facing the engine
The spring on the throttle shaft is tension to open the butterfly (clockwise) with spring return (counter clockwise)
Got a pic ? should cover the choke shutter
For some reason it won’t let me upload pictures. Do you have an email I can send to?
Daveb409@hotmail.com
“We don’t need no stinking”………. picture. You got it right, the throttle opens clockwise, the spring snaps it shut counter clockwise. All the early green-tank Mercs work the same.
Certified JB weld
Thank You
check you email . got yours and sent a reply.
OK
