Home Forum Ask A Member Mercury Mark 6A
  • #197795
      Hey guys and gals!
      Hoping someone can help me out. I have what I believe to be a 1959 Mercury Mark 6A. In sandalwood. Which conflicts with everything I have read about this year 6A.
      Any Mercury gurus out there can maybe shed some light on this for me?
      • This topic was modified 4 years, 11 months ago by Mumbles.
      #197805
      chuckw
        US Member - 2 Years
        OldMercs.com lists Sandlewood as a color for Mark 6A. Not sure how many came in that color.
        #197852
        jp53-n
          Neat engine, good for you. I sure would like to have that one.
          #197963
          fifty20ne
            A couple pics of motors.
            mark206s
            178562_417408608312091_1443143581_o
            scan0012
            MERCURY OUTBOARD PAINT
            MERCURY PAINT CODES
            Submitted by John Bennig
            I have compiled the following over several months mostly from John’s web site. Everything is from other people, so I cannot personally say it is accurate – but I believe it is.
            First, on bare aluminum a self-etching primer must be used. People use different types of paint, but a favorite seems to be PPG “concept”. It is a single stage urethane. I have heard that the only safe way to use this paint is with a fresh air respirator – the “chipmunk cheeks” type will not filter out the poisonous vapors.
            These numbers are for paint used in a spray gun. The “DCC” prefix is used unless you want to use a clear coat. Then the prefix is “DBC”. The following are PPG numbers:
            · 3398 Cloud White — May need flattening to look original – alternative 1992 VW Cashmere White
            · 91786 Dover White — someone suggested this as an alternative to Cloud White
            · 45183 Cedar Green — Windsor Green Dupont # centari 7498A
            · 3255 46-90 GM Dark Green — an alternative to Windsor Green
            · 981 Glossy Silver — add flattening agent to duplicate “Dull Aluminum
            · 73845 Holiday Red — ’93 Izuzu Coral Reef
            · 72146 Sunset Orange —- add a little flattener
            · 22998 Sand Tan
            · 2824 Marathon Red — (Firecracker Red)
            · 72358 Double Red
            · 51051 Burgandy — This may be too light. Try 51938 and reduce the metal content and size.
            · F2266K Quicksilver Green — This is a Dupont Chromabase number. Plasticoat spray can #312
            · Possible match 401093 but also not correct — all have too much, and too large metallic
            · pieces
            · 19114 Bimini Blue (bluish green)
            · 2824 Matador Red
            · 15003 Sarasota Blue
            · 2000 Marlin Blue—Two tone blue-one of two
            · 4290 Gulf Blue—-Two tone blue-two of two— Dupont # centari 7498A,
            I have not found paint codes for the following Mercury colors. Can someone else help?
            · Canyon Copper
            · Sandalwood
            · Metallic Charcoal
            · Buckskin Beige
            · Aztec Copper
            · Cavalry Brown
            For spray cans Dupli-Color DE 1650 Cast Coat Aluminum engine enamel is the best match for dull aluminum that I have seen. DE 1644 Racing Green engine enamel is close to cedar green. Both are supposed to be gas-proof.
            • This reply was modified 4 years, 11 months ago by fifty20ne.
