Home › Forum › Ask A Member › Milemaster pressure tank rebuild
- This topic has 6 replies, 4 voices, and was last updated 9 years, 11 months ago by
aquasonic.
March 25, 2015 at 11:21 pm #1027
Hi,
I have a tank rebuild kit with a 1/16" thick cork and rubber gasket and round washers also 1/16 thick cork and rubber for the 8 hold down bolts . Should I use 3M Scotch Weld 857 gasket adhesive on the gasket and the washers? One side only? How about on the rubber diaphragm?
Thank you.March 26, 2015 at 1:32 am #12783Olcah,
When I did mine, I didn’t use anything but the gaskets. Make sure everything is nice and clean and it should work fine.
How you coming on your RD?
March 26, 2015 at 1:56 am #12786My RD15A ran in a bucket last week but not well. I found that the coils, set exactly at the machined stops, were very lightly rubbing the flywheel magnet. I set the coils back using tape on the coil heels as a spacer and when the pressure tank is ready I will make another run. The problem could also have been aggravated by the leaking pressure tank and by ingesting its own exhaust.
The RJE18 also started and ran poorly. Later I noticed on pulling the motor over manually that very little air came through the motor end of the tank connection. I will probably take a look at the leaf plate as I did see some corrosion there when I rebuilt the carb.
What is the status of your RD16? Spring is coming.March 26, 2015 at 6:11 am #12797quote OLCAH:My RD15A ran in a bucket last week but not well. I found that the coils, set exactly at the machined stops, were very lightly rubbing the flywheel magnet. I set the coils back using tape on the coil heels as a spacer and when the pressure tank is ready I will make another run. The problem could also have been aggravated by the leaking pressure tank and by ingesting its own exhaust.
What is the status of your RD16? Spring is coming.OLCAH,
Spring is coming. I have the RD ready to go once the weather warms up a bit. I will run it in the bucket in the driveway and see what happens. Can’t wait to make some smoke!
March 26, 2015 at 12:51 pm #12803Over the winter, I rebuilt two of these tanks. I choose to use gasket sealer on the top cork gasket and coated all four surfaces before assembly. I also coated the eight screws that hold the cast aluminum tank top to the steel tank.
I believe these gaskets came with a gasket sealer from the factory, and the extra seal there can only be a good thing. You don’t want to have a pressure leak or worse, leaking fuel.
On the rubber diaphragm, no sealer was used, just a little grease on the eight diaphragm screws.
March 26, 2015 at 8:40 pm #12818When installing the diaphragm, you are supposed to apply a thin coat of 3M 847 around the hole in both cupped washers. The side the diaphragm contacts. This is to eliminate air leaks at this point. Fuel could also leak out under the pump button.
Gasket sealing compound is not called for on the gasket nor the screws, however, as stated, I don’t think it would hurt. I put OMC Gasket Sealing Compound, or more 3M 847 on the screw threads and on the gasket itself.
March 26, 2015 at 9:03 pm #12819quote Chris_P:When installing the diaphragm, you are supposed to apply a thin coat of 3M 847 around the hole in both cupped washers. The side the diaphragm contacts. This is to eliminate air leaks at this point. Fuel could also leak out under the pump button.Gasket sealing compound is not called for on the gasket nor the screws, however, as stated, I don’t think it would hurt. I put OMC Gasket Sealing Compound, or more 3M 847 on the screw threads and on the gasket itself.
Chris, are you referring to the older style tanks with the aluminum pump button?
I recall a post by Garry stating that OMC changed over to the plastic button setup partly because they did have problems with gas leaks through the aluminum buttons. I think that is why they eventually went to the plastic button with no button hole in the diaphragm.
