Home Forum Ask A Member Minimum HP for antique hydroplane??
  • #5233
    paulfromyork
      I’ve seen a lot of hydroplanes in the photo section. What kinda’ HP do you need at the minimum. They look like FUN.
      #43868
        They are classed by engine size. Class M (midget) is 7.5 cubic inches. Mainly for lighter weight people. they put out 7 to 10 HP, The record in the 1940s was 42 MPH. Class A is 15 cubic inches. Speeds in the 50s. B class in 350CC – speeds in the high 50s – C class – 500 cc – 31 cubic inches, Speeds in the 60s.
        Antique C class is popular. most running PR Johnsons or Modified Evinrude Speeditwins. The Japanese Yamato is a more modern racer and gives a good boat ride. For REALLY antiques – The Elto high speed Speedster was a nice hotrod of the late 1920s. The Elto Quad was also a head turner in it’s day. The first four cylinder outboard that started the horse power race that was brought to a halt by the "Great Recession" of the early ’30s . . . 😀
        #43962
        chinewalker
          Yep, all depends on the boat you’re running. Would never put a D class engine on a J/M class boat, or vice versa.
          #43965
          jw-in-dixie
            Not a hydro, this is a one-off home-built (1951) vee-bottom 8′ runabout made from two sheets of 1/4" marine plywood. Very stable and responsive on the turns.
            Initial motor was a 1940 five-horse LT10 Johnson because that’s all I had. Lucked up on a Mercury KG7 Super Hurricane shortly thereafter, and ran it for fifty years, logging more than 7000 miles. Got a Merc 200 (22 HP) powerhead, put it on a KE7 tower with the original KG7 lower unit and have been running it since.
            Lots of fun, cheap to build. I’m waiting for a cool morning to hit the water again, at 84. 😀
            #44022
            paulfromyork
              Are there sources for plans for this V-bottom beast?
              #44023
              Tom
                I built a similar boat called the Blue Streak when I was in high school. I got it to plane with a Zephyr and a skinnier me. Plans are free at:
                http://www.svensons.com/boat/?p=Runabou … /blustreak
                The picture shows someone sitting upright in the boat. That guy would have to be shorter than 5 feet to do that. But even kneeling, it was a lot of fun. I didn’t have a steering wheel in it, too many different motors that would have to be adapted, and none had a remote throttle. Most fun was a ’29 Evinrude Fastwin. Stupidest was a MK-20.
                T
                #44026
                cajuncook1
                  quote jw in dixie:
                  Not a hydro, this is a one-off home-built (1951) vee-bottom 8′ runabout made from two sheets of 1/4″ marine plywood. Very stable and responsive on the turns.
                  JW in Dixie,
                  You may be 84, but that picture in 2008 of you in your hydroplane has the spirit and grin of a teenage kid!! That pictures always puts a grin on my face!!
                  Cheers,
                  Cajun
                  #44602
                  paulfromyork
                    So please pardon what I don’t know. What’s the approximate HP of a 4 cylinder two stroker? I’m thinking somewhere around 10HP? I know, I know. It depends. Displacement and stroke and more. I guess with a hydroplane, more is better, until the boat sinks stern first. That would be too much motor.
                    #44603
                    wedgie
                      An Evinrude Zephyr has four cylinders that puts out 5.4 hp . I believe it is the smallest 4 cyl outboard made.
                      http://www.oddjobmotors.com/ihatezephyrs.htm
                      #44607
                      2fast4me
                        Evinrude Lightfour, bout 9.7 HP, not so light though. Well Light is relative I think 67 Lbs. Mine gives a nice ride on my 12 ft AlumaCraft. Best Wishes.
                        2Fast4Me
